2019 license plate lights
smit303
How hard is it to change these out to led's? i looked under there and they looked tucked up so high i couldn't spit on them. the K2's weren't that bad. Anybody do this yet? Any recommendations on what bulbs to use?
  • Replies 64
It looks like it will be a PITA to change.  The tow hitch support runs under the license plate bulb connector and there is little space to reach it!
Yea, that's what I thought. I guess I'll have to live with the dingy yellow stock bulbs.
I don't know what GM is thinking buy not changing all the bulbs over to LED but since it is a ground up new truck and most of the other bulbs are LED why not make all of them LED.
I think they may be the same as the K2's bulb.
Here is what i used with great results and in stock nearby....
1 hour ago, OneTruck60Mexicans said:
I can confirm they’re the same size bulbs as the 2018s (194).  I bought a set of HP3s from Diode Dynamics - https://www.diodedynamics.com/license-plate-leds-for-1998-2017-gmc-sierra-2500-pair.html.  I took a chance because the truck is so new it was difficult to confirm.
It’s a little awkward to get to and remove the sockets, but definitely doable.
Good to hear that it's doable. I'll buy a set and get em in there somehow.
15 minutes ago, Pyrojodge said:
Its doable... PITA but doable... 6 inch channel locks help for those with large hands...  and about 10 minutes.
What bulbs did you install? They look great
Thanks... heres what i used.  I was concerned that with the rear view mirror camera and back up camera they may flash but all is well.
Tail lights: AUXITO 912 921 LED Backup Light Bulbs High Power 2835 15-SMD Chipsets Extremely Bright Error Free T15 906 W16W for Back Up Lights Reverse Lights, 6000K White (Upgraded,Pack of 2) https://www.amazon.com/dp/B0728DYR9H/ref=cm_sw_r_cp_apa_7sE9BbH185JEP
License plate lights: AUXITO 194 LED Light Bulb 6000K White Super Bright 168 2825 W5W T10 Wedge 24-SMD 3014 Chipsets LED Replacement Bulbs Error Free for Car Dome Map Door Courtesy License Plate Lights (Pack of 10) https://www.amazon.com/dp/B071LHP5WP/ref=cm_sw_r_cp_apa_ouE9BbRCAANBR
I was able to change my license plate bulbs out, I have skinny hands, so that helped, but still a PITA.
I agree - why didn't GMC just put LEDs in from the factory???
