Transmission lines leaking?
anm8
Hi everybody,
Just bought my first GMC a week ago.  It is a 2016 with 55,000 miles 5.3 SLT 4x4 with Z71.  I looked the car over pretty good but noticed something after we got home.  Is this the common leaking crimps I have been learning about on these vehicles with transmission lines?  I have to crawl under the vehicle this weekend but this was the picture I was able to get. The gunk had no smell to it at all.
And not sure if the Rancho shocks are completely shot on this Z71 package but on the highway and my first speed bump the words....Old Cadillac came to mind about how much it wallows.  Thanks everybody for your time....
Unfortunately, it is very common for transmission cooler lines and oil cooler lines to leak on GM products.  I had lines replaced on my '96 Impala SS multiple times, and also on my '09 Silverado.  Now my truck is leaking again; 3rd set of lines.  And I don't race/heavy haul/tow with my vehicles.  The dealer always use the real GM replacement parts, so apparently those parts are just no good.  They last about a year before they start to 'sweat' at the crimps, and then progressively get worse until they drip.  They say you can cut the crimps off with a Dremel tool and put on hose clamps and tighten the heck out of them and the leak will stop.  Or have lines built for you at a shop that specializes in hydraulics.
A lot of people on this forum have replaced the factory Rancho shocks with Bilsteins.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
