On 7/26/2021 at 3:08 PM, AlohaDan said:
STARTING MY LEMON LAW CLAIM:   After multiple attempts to get my intermittent screen going blank in my 2019 Silverado, I have decided to move forward with a Lemon Law claim and am working with a lawyer.    He feels confident that he can get GM to buy back my truck for what I paid for it.    Unfortunately, I've also spent money to upgrade the rims, install a tonneau cover, running boards, etc.   But, I'd prefer not to have to deal with this on a truck that I'd like to drive for 1-15 years.
What ended up happening after the lawyer got involved?
Mine will not work for DAYS sometimes, and the screen will flash on and right back off once every minute like it is “trying” to boot up. But this has gone on for so long now (over six months) that I know it will not pick up and work until after the GMC logo page appears. I thought it might be a bad contact in the module because it would come on first thing in the morning if it was ‘cold’ outside and then not connect in the afternoon. I am at a loss for a reason. But if this is how GMC manages these issues by just ignoring them. I will trade this 2019 GMC Sierra 1500 with the Elevation package in on a Dodge.
And have similar problems.  Try a titan or a tundra.
O.K. well I guess I am not alone on this subject. I have not seen any recent posts about this since 2019. It is now 2021 and I just experienced this issue on my 2019 Trail Boss. Not controls, blank screen and the radio could not be turned off or down, or change the channel. I turned the truck off then on again. Nothing... When I arrived at home, I checked fuses all good. I went to back it into the garage and it magically worked. No clue how or why. I did not reset, pull fuses or anything. It just decided to work again, which worries me more as this sounds like such an intermittent problem, like most electrical issues (goblins in the wires). Anyone have a fix or has GM announced a fix yet?
My dealership service tech has a "tech case" open for 6 months now on my 2020 with no reply yet from Chevy software engineers; tech said 8 months or more is common for a reply. Tech's best effort was to reset the radio/MyLink system with factory default and showed me how to do it if blank screen happens again. However, display has to be working to reset: tech's tip was to shut off truck, open/close driver's door, and let truck sit for about 20 minutes & display should work again. When I checked last month on tech case, I complained that my Silverado is two models years old and that there should be a fix by now. I was told it is a "software anomaly" and there may never be a fix. Pretty upsetting.
I left My 2020 Custom  4 four times in the last year at dealership for radio repairs.
Repairs so far in year 1 and 4 months
1st reset  radio  (black in three weeks)
2nd reset the radio update the radio (black screen after two weeks )
3rd Replaced the radio after sitting there for 3 weeks and soon as i rolled of the lot shuts off goes black.
4th Reset the radio again ( requested a full radio upgraded and waiting on the response now )
Frustrated is not even the word for it!
https://www.carcomplaints.com/news/2020/gm-infotainment-system-problems-lawsuit.shtml
Yes it must be a GM thing. Bought a new Silverado in 2016, by the end of the year it was blacking out. I was told to take out a fuse and wait 15 seconds. This solution worked but it was extremely an annoying. Bought a  2020 Silverado this past August and today the screen started blacking out again. Im done with GM, piece of ******! next truck will either be Dodge, Nissan or Ford.
Do you have the 8 inch or 7 inch display ?  Make sure you record the issues if you can because they try to use a logging system that records after 1 minute time frame for system failures  not seconds  in which most of the failures were 16 to 25 seconds.
My wife's 2021 Armada goes in tomorrow because her infotainment screen shuts off/restarts 3-5 times a week.
Just a heads up.
My 2021 Silverado 1500 that I bought in August just started doing this. The first time the entire radio shut off and went black for about 15-30 seconds while driving and came back on.  Then today, screen went black but the radio stayed on, but could not be controlled.  Parked the truck and shut it off, opened doors and got out, and the radio still stayed on.  After about 5 minutes it shut off and then was fine when started back up.
Does anyone know what the current version of the software is?  My truck says it's up to date, the version number is v135119-LS.
My 2021 Silverado 2500HD did the same thing this a.m. on the way to work.  Bought last July.  Screen went black, radio still worked.  Backup camera worked, parked the truck and the radio stayed on after turning the truck off and closing the doors.  Went back out to pull the fuse 5 minutes later and everything was OK.  Disappointing to hear this has been an issue for a couple of years now.
Make sure you go to Chevrolet directly to make the appointment
here is the direct text number i used for the appointment
Chevrolet direct support  number via text 62836  (have your Vin ready for fastest service.)
Thanks guys.  Ended up taking it to the dealer on Monday.  They couldn't reproduce anything, so they just reflashed the system with the latest software.  It's been ok so far.
They did say that sometimes the radio will do something like that if it tries to push a software update etc...  But it looks like the software they loaded was the same version from last April.  So not sure why it would have been trying to update...
OK , this is how my radio blacks out all the time USB connected  application on phone launches everything gets hot screen blacks out android/apple either cable attached to phone.(10 plus times with a new display/radio installed)  Hint: attach your truck to your home WiFi  that way it auto-updates all the time. The receiver is like a cellphone looking for towers for signal if you have the 4glte service equipment install.
Settings
Wifi
see your home WiFi signal
select it
then input your WiFi password
then your truck will be connected to your home WiFi for updates and service diagnostics.
Après avoir vérifié les fusibles, appuyé sur tous boutons, essayé les resets...j ai pressé en même temps la fermeture automatique des portes et des fenêtres, et miracle, ça fonctionne!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
