Just purchased a set of 2019 Silverado take off wheels and tires for my 2014 truck   - Thought I could simply take off the old wheels & tires and bolt on the new ones.  Somewhere deep in the fine print of my purchase it says that the frequency for the tpms was changed in 2019.  Anybody know if that is true?  I don't want to take off the old wheels and tires, only to find out I'll have to un-mount both sets to put in my 2014 tpms on the 2019 wheels
From what I've seen and heard, the 19 sensors will not work on 18 and prior and the other way around. That goes for the 2500's also.
Thanks - looks like I'm going to the tire shop for some work
Yeah according to that thread his local Discount Tires couldn’t do it for him...might have to do the dealership thing or at least call whoever before a visit.
Local shop had me in and out in about an hour - added my existing sensors to the new wheels/tires - working great
They knew about the frequency issue & had no problems getting things working
Anybody need some 433MHZ  sensors for a 2019 truck - no stems - Like new - less than 100 miles
Tire rack is selling them for $50.00 each - make me an offer - Free shipping
  • 9 months later...
Digging up this old thread cuz I'm dealing with a similar issue. I'm trying to put some 2018 wheels on my 2019 and I was quoted 400 bucks in labor to complete the sensor swap. Seemed a little high to me. Was yours in that same range?
You need to find another shop - My bill was $85.00  - This was at a regional tire shop  in Michigan called Mr Tire - I would try to find a shop that only deals with tires & related labor.
  • 4 years later...
CPR Time, bringing this to life again.
Put some 2022 AT4 takeoffs on my 2015.  My DIC shows the pressure for each tire, I figured it would not.  Only problem is the numbers are all off.  Using a pressure gauge they all show 35-36, but the DIC shows 30-31 for them all.  I tried a hand gauge and also went to a gas station and used theirs off the air pump, both were reading 35-36 psi.
What do I need to do? I will also add I swapped these in my garage and only have driven maybe 5 miles on them.
Just a guess, but are you old tires still nearby your truck when you are at home?  I suspect your truck may still be learned to the old sensors in the wheels no longer on the truck.  Add to that you haven’t driven far enough yet for the TPMS faults to set for not being able to read the sensor (because it’s still at home and no longer in range).
I’ve never heard of a 433 MHz sensor pairing and sending ANY data to a 315 MHz system like your K2xx truck is.
Yea my old tires are in my garage that my truck is in! I figured it wasn’t them as their pressure was around 34-35 when I pulled them off. You think that number would change once the weight of the truck was no longer on them unmourned? Seems kinda to make sense.
I’m still guessing I’ll need new sensors put in them if that’s the case since the frequencies should be different in the 2022s.
Edited by Skeeter McSkeet
The pressure will not change with or without the weight of the vehicle on the tire.  It will change pretty significantly with temperature though.
If you never did a sensor relearn procedure on the truck after replacing tires, you can be sure it is still looking for the sensors in the old wheels.  Each sensor has a unique transmitter number and this is what the TPMS module in the truck is looking for.  The relearn simply changes this association.  You can think of it just like a paired Bluetooth connection.
Ok took a 100 mile trip today and they weren’t recognized after about 25 miles. Will our trucks relearn the new version sensors in them? Saw some replacements you can screw in from the outside it looked like, made to swap winter/summer wheels. No idea on them.
You need 315mHz sensors.  New wheels so 2019 T1 and up are 433mHz and won't talk to a 14-19 old truck.
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
