3 hours ago, gossipboy said:
I found a company that makes a bypass that only makes the Task Lights work while driving when you turn your brights on.
prove it.  :)
3 hours ago, Blong7328 said:
Boost automotive has a product that does have the mirror lights on with high beam but does not have a way to shut off and on.  also some do not like the T-tap connection and would rather use a diode method of this mod.
Right. That is what I plan to do. 1N4004 diodes. I download the wiring schematics from uplifter, just have to take the time to figure it out. Boost automotive has some YouTube videos that will help to.
https://www.gmupfitter.com/files/media/photo/1161/19_Silverado_1500_Body_Builder_2019FEB13.pdf
On 1/23/2020 at 11:37 AM, EXSlider400 said:
I plan on making it so the fog lights and the mirror lights turn on with the brights. Just have not had time to look at what connections will need a 1-way resistor
Any luck with that? I was going to just make my own harness, because $70 seemed like a lot for something that I had to Ttap into my $50k truck....
Not yet. I downloaded the diagrams I just haven’t went through them.
  • 3 months later...
Does anybody know the part number for the light in the mirror I was driving down the highway and a rock hit the light and chipped the housing and it just looks bad with a big hole in the middle of the light and water is getting inside?? Part number??
Edited by AngelG.97
  • 8 months later...
On 5/25/2021 at 3:30 PM, Anjac12 said:
Is there a work around to get the mirror lights to be turned on while the truck is in gear?
Boostauto makes a harness for it. You can run them when you put the high beams on.
A lot late to the party, but 3 posts up, the one and done is asking for a part number???
There is a QR code right on it in plain site, how do you afford a new truck when you can not even figure that out🤔
Yes! This kit makes it so when you use you high beams both mirror lights come on also. https://boostautoparts.com/products/high-spot?utm_source=GM+2019%2B+High+Beam+to+Spot&utm_medium=Description&utm_campaign=YouTube
You end up finding your way around this? I see Boost’s product but can’t imagine $50 in actual parts. Looks like 2 connections between brown and grey BCM and a fused link and a relay are what they used.
I have a ‘21 rst and I have task lighting. But I do not have the mirrors. If I get a set of mirrors, will they work as they should since I have the rest of the task lights, or will other things need to be done as well. Thanks in advance
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
