Is the Trail boss a bad deal?
4 hours ago, gothp28 said:
All gmc and chevy sit with the front lower for Aerodynamics regardless if it's a standard, denali and trail boss.
Sent from my SM-G965U using Tapatalk
I don’t think the 19 non trail boss trucks have nearly the rake the 18 and older do.  We were looking at them side by side the other day.  Trail boss vs non trail boss that is.
On 12/21/2018 at 10:53 AM, Chris walker said:
I'm a HUGE fan of the Trail boss...with that being said the more I play with the build/configurator on Chevy's website Im not sure its that good of a deal. I can build an LTZ premium with many more options (some unavailable in a Trail boss) for about the same price. I realize it doesnt have a 2 inch lift but I can pay the dealership to add Chevy's lift and add some nittos for a couple of grand. I'm sitting in a MUCH nicer truck for just a few grand and still be under factory warranty. I optioned out a high country and it would only be about 5k more than a trail boss after chevy lift and tires. Im feeling like Chevy is sitting on a gold mine and will be stuffing money in both pockets with the Trail boss...Am I missing something?
The only thing stopping me from going this route is the chrome on the LTZ/High Country...Im not a fan of the chrome. If Chevy comes out with an LTZ midnight/dusk edition its not going to be a tough call
I plan on ordering LTZ Z71 with 6.2, the 2 lift, and the black accessories at the bogging of the year.  My dealer is well aware I usually have him do extras when ordering.  My current ltz has all paint matching they had to install when truck arrived.
good thing was I was able to sell the chrome stuff after.
On 12/21/2018 at 7:39 PM, GMC-AT said:
Yes.. on my RST order (fully loaded) I couldn't get power side mirrors or power passenger seat.. no matter how much $$$ I spent.  These are the two things I wish the RST had.   I could get an LTZ that has this stuff, plus vented seats, rear heated seats, etc,  for less $$.
But I just can't stand the chrome exterior of LTZ, etc.
That's a big reason I went with the High Country.  The RST was more my style on the outside, but I wanted the 6.2L and other interior features.  The deluxe 22" wheels look good too, so that's what finished the deal compared to going for the LTZ and replacing the wheels and chrome.
Sounds like the best bet is to purchase an LTZ with the goodies you want..... and then have the grille, door handles and bumpers painted.
Have you looked into adding the RST door handles and front grille to the LTZ?
Ryan B.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
