Is it actually working? I have no idea and haven’t been able to tell... compared to the 18 I drove where I noticed right away and then the salesman pointed out the little v4 light to me to explain it...
It’s almost unnoticeable...  but all the gimmicks have done nothing to improve mileage.
I mostly tow... My 14 6.2L did better.  Towing my usual trailer, I’d average 10-12MPG with my 14.  The 19 is 9-11MPG with the same trailer.
9 hours ago, fishingtruck said:
Good information, I would have thought the 10 speed helps improve efficiency especially while towing.
Me too ...  but my last truck was the 6 speed .. ran about 2200 RPMs at 70mph.
The 19 runs at around 1800 RPMs at 70mph.
Everything about that metric makes you think the 19 should kill the old truck in mileage.  Its simply not the case.
The only other major difference is the 19 has 22" wheels vs the old one with 20"
Edited by steve841
My 2019 double cab 5.3L has it and it is less noticeable than my 15- I had to run a Range AFM disabler in my 2015 because of the constant shifting and vibrations- The range made it behave like it should. My gas mileage was also very consistent , 15-16.5 mpg compared to my tundra's which ran 13-14mpg.
I will disable the new one also, once range can update my device, my commute is hilly terrain and the new truck has slight vibrations around 30-40.
I have a question for the group, when I drove the new 2019 on the test drive I made sure I traveled my normal route. There was no signs of even the slightest vibration or hesitation. Now I have bought it, there are slight signs of vibration under light load starting up hills or on level road when trying to accelerate.
Do you think the DFM is disabled on these trucks until you purchase them? This is a big question because it would speak towards unfair sales practices?
I wondered this on my 2015 also because when I test drove it it also was very smooth. If I didn't find the range device it would have been sold.
could be the new front end's aerodynamic qualities are lacking? I noticed the old denali had seat belt adjusters and vertically adjustable lumbar which are no longer in the new model? but with lighter weight and the 10spd you would have thought......well i don't really know
Aside from the mpg... which truck towed better from a confidence standpoint?
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
