Only miles will tell if DFM is a problem. Hope they fixed those lifters. And the DFM does have as much if not more than AFM going on mechanically. And the software and number/swiftness of decisions the ECM makes ....Tech article:
As you probably are aware, AFM was a relatively simple system which converts a V8 engine into a four-cylinder (operationally) by deactivating four cylinders. DFM expands on this idea by installing the AFM style, spring-loaded lifters in all 16 positions so that all eight cylinders (instead of only four) can now be selectively deactivated.......Mechanically, DFM is just an extension of the earlier AFM system.
They have levers in the lifter deactivation chain. As to running smooth and cannot tell DFM is there, see this: more mechanical ,
These new DFM-equipped trucks and SUV’s will also be upgraded with what GM calls a “centrifugal pendulum absorber” in the torque converter. Essentially, this is similar to a dual mass flywheel for a manual transmission. This pendulum absorber employs coil springs mounted to a plate splined to the input shaft of the torque converter.
This pendulum device will isolate noise and vibration between the engine and the transmission. When cylinders are deactivated, the number of crankshaft rotation increases between firing pulses. A V8 firing all 8 cylinders sees 90 degrees between combustion events, while a 4 cylinder engine lengthens this to 180 degrees. That inherently less smooth operation requires additional NVH dampening.
https://www.enginelabs.com/engine-tech/gm-escalates-cylinder-deactivation-with-dynamic-fuel-management/
  • 2 months later...
I notice A LOT of Engine lag form my 19 Silverado with an aftermarket exhaust When the DFM kicked in , could that be the reason? Drove my neighbors Silverado of the same year and couldn’t feel it at all.
  • 6 months later...
creeping on 25k miles, check engine light came on 2 days ago U0284 (Active Grill Shutter No Communication) that is about it and it is overheating if i have the plow on while going 45mph or faster.
It works fine and I do seem to get "slightly" better MPG with it enabled but I can feel it and hear it doing its thing.  I prefer how the truck runs with it disabled.
-Eli
    • I understand. It is disturbing to think a manufacture asks so much and gives so little in engineering support. This is not a GM issues, this is a greed issue and one the ALL practice.    My intent was not to remove the wind from anyone's sail but rather to point out the areas deficient so that they can be discussed with improvements the goal. But to do that you have to know the truth and what that truth is.    The commercial interest are honed in on a few select issues in which they control all the variables and are not forthcoming in the least with their customers about the details. Failure is the only thing that drives these people to improvement. One way not to fail it to manage public "expectations". The set a bar they can clear and put their thumbs under the suspenders with chest puffed.... Only the internal data tells the story fully. As we don't have access to that for decades then we have to generate it ourselves. UOA's with data that matters.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
