Organization in bed? Net? what do you use?
I'm curious to know what people are using for Bed organization? If I pick up groceries, I want to be able to put them towards the rear of the bed without them going all over the place. Not looking to spend a million dollars here, a cargo net may be fine
In my old pickup, the bed liner had molded inserts for 2x4s so I cut a 2x6 to width and would hold groceries nice.  My van and Yukon both have the envelope nets, stuff can be put inside the net to keep it from rolling around.
In my current truck(2015 Silverado) I have the decked system.  You can now order it from Chevy and also include it with your truck build.  It’s by far the best thing I’ve ever purchased for a vehicle.  I will not go without it again.
Im about to order a new truck after the holidays and of course it’ll be included
I use cargo bars as well.
That said, the new wider bed was too wide for my ratcheting cargo bar and it will only fit on the wheel wells.
Are you listening Harbor Freight? :D
1 hour ago, StevenStarke said:
So the 2014-2018 extender fits no problem?
Should be no problem.  You have to drill holes to match the bracket after you remove the taillights assembly.  Getting the nuts on the back of the bracket bolts is a little tricky due to the tight space, but it can be done.
I've been looking at the decked system....It will be a must have addition for me and its good to hear you've enjoyed it. Im assuming the quality is good from the amount you've liked it.
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 587 Guests (See full list)
