Lease upgrade?
How early has anyone been able to get out if they’re lease and into a new gmc?
I am right at a year left on my current lease
Thanks
Thanks
I was two years into a four year lease.
It totally depends on your payout and what truck has for features.
Mine was a loaded SLT All-Terrain with only 29,000 kms on it, so they could flip it easily.
Sent from my SM-N960W using Tapatalk
I’m thinking my only option would be for gm to allow me upgrade lease early and not try to have dealer trade it in because there are a lot of 18s they are trying to blow out currently
I'd give the dealer a call. But ask to speak with the Sales Manager and see what they can do for you. Mine was a '17 that I leased, but I purchased my '19 AT4..
Agreed the the poster above as it will all come down to what you owe/what truck is worth. I would hit up a few different dealers , tell them what you have and what you want and the price you want it at.  I still think a year is too early but it can’t hurt to ask especially this last week of year. Low ball the mofos.
I’ve leased a few vehicles, and historically I get a call 6 months before the end of the lease to come in and trade up. I’d imagine if your current lease is under your miles and in good shape, someone will work with you.
I'm about a year out on my lease as well.  I'm going to be patient and see if the prices don't relax a little in the next few months when the 18's are finally gone. GM is currently very proud of these 19's.  If they don't come down, I may have to look at other brands.  Hoping for the best.
I was told by the GM at the dealer I bought mine from, that the interest rates for financing and leasing will drop way down, before there are huge deals on the price itself.
I'm in Canada though, so that might be a different case compared to the States.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
