3 hours ago, yankeedoodle86 said:
They’re not mud flaps. This thread labeled them such for lack of a better term. Their intent was to promote the aerodynamics for the truck....they look hideous and probably add .01% fuel savings.
but he's removed the front mud flaps. Legitimate flaps ahah
On 12/29/2018 at 2:05 PM, Jerry's Denali said:
Give a 14 y/o $4 worth of oracal satin black vinyl and 15 minutes, this is what he comes up with.
Cleaner look without the "granpa" mud flaps hanging down.
Can he make another set? I’ll pay him!!
  • 7 months later...
  • 8 months later...
On 5/21/2020 at 11:11 PM, EricTheRed said:
Are these available to buy yet?
I'm not sure they are the OP's design or not, but I got mine here.
https://switchsuspension.com/chevrolet-silverado-1500-2019-2021-front-rear-mud-flap-delete-kit/
WAY too much money for what you get, but I *needed* the back ones.  I added an AMP bed step and depending on the installation hit either the running board or rear Aero flap.  I removed the flaps, but couldn't stand the look of the holes so I bought these.
I only used the rear, so if anyone needs just the front pcs, I may sell those...
These are $10 for 2 on sharptruck.com perfect option for the money... all Chevy colors...they are called fender plugs and they’re made to put in the mud flap hole
Edited by Luckyfd
These don't work on the rear.  The rear holes are oblong slots....
Mine are all oblong holes and the fit good. As a matter of fact that picture is of the rear
Cool.  I couldn't gauge the size.
The website says they are for the front only.  I've already spent the money and installed the others, so no crying for me now, but I wish I had seen these.
Lol I didn’t read that...thankfully not paying attention didn’t bite me in the butt. They do fit a little tight in the rear but still fit.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
