2018 Chevy 1500 4x4 Speed Control not working at higher speeds
Need Help;
My New 2018 Chevy 1500 4x4 with only 1800 mils speed control does not work at highway speeds, only at lower speeds below 40 mph. Once it gets above 40 mph the speed control shuts off, the on light stays on but the speed control will not engage. Once I get below 40 mph the speed control will start working again.
Existing condition of the Truck;
I bought the truck brand new off a Chevy dealer which already had a 6" Pro-Comp Lift and with 35"x 12.5"x 20" tires/rims installed on it.
The Chevy dealer had a company call DSI install all their lifts on their new trucks.
DSI also installed an Hypertech inline speedometer Calibrator.
I was told that the truck is covered under the chevy standard warranty and DSI covers anything that Chevy will not. [This is also in writing]
After I bought the truck I took it to a local well known 4x4 off road shop and had them replace the stock 3.42 gears with Chevy 4.10 gears.
The truck runs great ! The only issue is that my speed control is not working at highway speeds.
I did take the truck to another local Chevy dealer that's closer to where I live, to make a long story short they did try to diagnose the problem but could not find anything. All they could say is that it might have been something to do with the lift kit or the gear change and I should bring it back to the dealer whom I bought it from which I have already schedule an appointment.
DSI did remove the Hypertech inline speedometer Calibrator but made no different.
Has anybody else had this issue with there truck? If you have and you had if fixed what was the problem.
Thanks,
Dave -
Need Help;
Thanks,
Dave -
When you say speed control are you talking about cruise control? And did your truck get recalibrated for the new gears?
Sent from above
The "Speed control" got me. It's like hearing indicator light rather than turn signal. Any hoots I would definitely be taking the truck into the dealer for a checkup.
Sent from above
Yes, Cruise Control.
Yes, The original dealer installed a Hypertech inline speedometer Calibrator.
They’d installed the Hypertech and then you did the gear swap, right? After the gear swap was the Hypertech adjusted for the lower gearing?
Yes,
I just got it back from the dealer.
The service department told me it's because I installed the 4.10 gears and I was told that they do not not have a program for the 4.10 which is weird because I used stock 410 gears which is available through GMC. So for right now the truck runs great but I do not have cruise control for the highway speeds. Any suggestions? Thanks for your help.
Yes,
Get rid of the program period! Redo the truck with a new programmer like SuperChips $320 and start over. Changing out your rear ratio to 4:10 is on the F5. Set to performance and change tire size along with other personal preferences and then the rear end, takes a few minutes.
Sent from above
Sent from above
Bingo
Sent from above
Thank you !!!!
On 1/18/2019 at 3:24 PM, TXGREEK said:
Get it done? If not, keep us posted
Sent from above
I'm not able to have this programmer sent to me because I'm in California.
I have been looking for a tuner that i'm able to have shipped to me but have not had any luck.
Any suggestions?
Any suggestions?
Yes, drive somewhere that does have it and get it done. No one can help you while you live in a socialist state. You can, I’m pretty sure you can order just the calibration unit for gears and tires.
Sent from above
Any suggestions?
HP Tuners perhaps.  Can always fine it used pretty easy.  It can do FAR more than any of these other tuners because it is the right way to tune the truck.  It is also the only tuner that can tune your transmission.
He’s got a six speed which most of them will do. I’d be cautious buying any used programmer. Some used programmers give to much added headaches and costs in order to recal them if they weren’t done correctly. Lots of used trucks out there being sold with programs still on them leaving the used programmers literally useless
Sent from above
Again, HP Tuners isn't some crappy hand held.  It can tune as many vehicles as you want - you just have to buy the credits.  No issues purchasing a used one.
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
