On 9/8/2020 at 7:17 AM, Steven Thibodeau said:
i noticed that the passenger side has tubes coming out of the block and into the air intake.  is there a catch can needed/available for that side?  i scrolled on the inner web and did not find a direct fit kit.
Yes that passenger (clean side) can use a can as well.  Here is a good explanation of how a dual catch can system works that handles the passenger side as well.
On 9/9/2020 at 10:57 AM, fortplainman said:
JLT looks like a good deal on the 6.2. Might be worth trying after this read emoji106.png
It’s an easy install and well made.
This is a great example of how the drivers side only units are only a partial improvement. Sure, they limit some of the oil from re-entering the intake and coking up the valves, but the valley and passenger side bank are still blowing by into the intake. With about 1000kms on the truck, i found a healthy amount of oil in the stock passenger side pcv tube when changing the intake tube. That passenger line enters the intake after the filter and right in front of the throttle body. This RXP kit is a mess, but it at least seems to capture all sources of recirc.
Elite catch can almost 2oz when emptied between oil changes
Ryan B.
Watched the video.
1.) It is impossible for a normally asperated motor to loose vacuum in the plenum unless that motor is not running at all. As long as it is running there is a pressure gradient. It can get pretty low but it can not reach zero.
2.) If you have more crankcase pressure than you have plenum pressure you have rings that are not sealing.
3.) That the case the catch can is a band-aid for a much larger issue.
  • 4 months later...
On 1/25/2019 at 5:08 PM, Smitty said:
I'm really curious if the 2019's will need one or not.   Anyone know for sure?
I am looking at the JLT 3.0 air/oil separator catch can.  It looks like a really great until and good quality
https://www.jlttruecoldair.com/jlt-3-0-oil-separator-2019-2021-chevy-silverado-gmc-sierra-1500-5-3l-6-2l-2021-chevy-tahoe-suburban-gmc-yukon-yukon-xl-5-3l-6-2l/
On 6/10/2020 at 11:17 AM, Grumpy Bear said:
Question Phillip. Does your truck use oil and what is your routine oil change interval? Thanks.
My Sierra 1500 has 26000km on the clock now and I have not noticed any oil consumption.  Although the dealer is still doing the oil changes at present as the truck came with two years worth of free oil changes, I check the oil regularly and before long trips and all good.  I am looking at the JLT  3.0 unit
So if your usage is nil then what will a catch can catch. Say that three times fast :)
Been reading up and researching on the coating etc. of upper engine parts/component with oil etc. over the longer term.  If what people say is true about catching half a can between oil changes, not sure that would show up on the dipsticks? What are your thoughts?
GM engineers didn't specify one from the factory, which suggests they didn't find it essential. The companies that sell catch cans, on the other hand, tend to suggest that these add-ons are very important , which isn't surprising. It's entirely normal for a modest amount of oil mist to circulate around in an oil-lubricated, internal combustion engine. Prior to about 1963, most manufacturers dealt with the oil mist by simply venting it out into the atmosphere. After that approach was rendered illegal, manufacturers added PCV or similar "closed loop" systems that handled the mist and relieved crankcase pressure by routing the oil laden air inside the engine through the induction system and into the combustion chambers. So, instead of venting out into the atmosphere, the mist got burned as part of the engine's normal operation. In some cars and in some circumstances, misted oil can accumulate in certain parts of the engine with ill effect. Also, oil mist may contribute to "coking" of intake valves. Coking is the solidification of oil resulting from severe oxidation and thermal breakdown, and it can occur when the oil mist is deposited on the underside of hot valves. This problem is more prevalent with intake valves in engines utilizing direct fuel injection, where the fuel is injected directly into the combustion chamber rather than into an intake port. With port injection or carburetors, the fuel passes over the backs of the intake valves and both cools and cleans them, reducing the likelihood of coking. When deciding whether an oil catch can is right for you, weigh the negatives against the positives. The negatives include the cost to buy and install one, and the need to periodically dispose of the captured oil. The positives include a reduced chance of coking, cleaner exhaust tips and maybe some extra peace of mind. WHEW!
"What people are saying" is an interesting turn of phrase. What people? Those saying it is true? Those saying it is so are those experiencing the problem. Those not having an issue are not saying, silent they are. What you are hearing then is by your own word is but half a story. My thoughts are that it is impossible to make a good decision based on half the facts. Even silent they tell the rest of the story. What is that?
If your motor uses oil and not leaking then use a can. If your motor uses no oil then the can is wasted money. The next question your going to ask is how much oil is considered 'using oil'. And it would be a good question. ALL MOTORS USE OIL!!
Yea, yea.....look if you can measure the usage on the dipstick in 5,000 miles...use a can. If you cannot then what little oil that is 'normal' for the motor to use will not cause an issue over its entire lifetime.
I don't have one on mine and thus far 135K on the clock flawlessly. Cameron took some photo's of his motor with quite a few miles on it that showed zip on the valves. There's guys on this site with over a quarter million without a can without issues.
Now my wife's Terrain uses about a quart in 10K. A cup in 2500 miles. I'd put a can on that one IF it was possible. 2.4 is internally routed and yea, that one has had the valves cleaned mechanically.
Situation dependent based on YOUR needs. That's what I think.
I've always ran the UPR Products stuff.  Seem to be good quality and I like the way it mounts on the battery bracket versus the JLT one with the coolant bottle just partially stuck back on the stud.
Technically this isn't coking. Coking is hydrocarbons heated to the point of hydrogen disassociation leaving nothing but carbon behind. The backs of intake valves in a running motor come no where near hot enough to coke. Not even in a GDI motor. Even in a refinery a catalyst is required at temperatures near 950 F. Sans such a catalyst coking temperature exceed 1400 F.
If it were 'coking' no fuel detergent would wash it away. Speaking of detergents...they are present in you motor oil.
What happens is more akin to leaving the lid off a can of shellac or the creation of amber from tree sap. A coating of oil bakes during the hot soak repeatedly building up layers. Motors that live on short trips and use oil can have issues. Not so much with motors that use little and who's mile are more highway.
This is the intake tract of the afore mentioned GM Ecotec 2.4/I4 whose PCV system plugged and rings collapsed and consumed oil at a peak rate of a quart in 600 miles. This one needs a can. Short tip motor that uses oil. This cleaned up with solvent and a wooden scrapper. 90K on the clock if I remember correctly.
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
