Finally got the kicker sub installed and hooked up yesterday. I ran into a few weird issues that no else seems to have encountered. I'll post pictures and the issues i encountered separately once i have everything buttoned up.
First impression is it really thumps and vibrates the back window. Thankfully i have the rear view camera so i don't need to worry about not being able to see through my rear window. It can get a bit boomy sometimes though. It's definitely not a  rattle your teeth loose bass. That's not what i was looking for anyways. I had the volume knob hooked up from day-one so i don't know how it sounds without it. Also didn't touch the switches. I'm still fine-tuning but here are a few pointers:
1. The kit taps into the front right speaker so will be affected by head-unit controls such as fade, bass, etc. It's especially affected by fade. Kicker support recommended i reduce the bass on the head-unit, fade a bit to the front or keep neutral and use the control knob the rest of the way. I right now have it set to bass=0, mid=3, treble=5 and knob=1/2 turn. Sounds good but still playing around with it.
2. Kicker support said the FlexTune app will not work with this sub kit. I tried multiple times on my phone for it to connect and it never did. They said the app only works with the full power-stage upgrade kits.
Really loving it so far.
I have a brand new kicker subwoofer with all wiring if anyone wants it’s. Do not do it if you have Bose. Without Bose it sounds great. 200.00 plus shipping. I had it installed less than three weeks.
What didn't you like about the kicker? Was it installed correctly and did you get the knob?
Honestly, i'm one of the few who actually likes the Bose system. I think it's balanced and has very good bass. My main problem with the Bose is that the front speakers carry the majority of the bass and it can cause unpleasant rattles and resonance with some songs. It doesn't happen for every song but every once in a while, i'll hear a song that brings out this bad attribute. I really didn't get the kicker because i wanted more bass. I got it to remove the majority of the bass from the doors to prevent these rattles. So far, it's doing a good job at that. Still fine tuning it though.
I did have the knob. It’s was just a waste of time if you already have the Bose system
Well, i'm sorry to hear about that. You could probably get more for it on Ebay. I would have purchased it from you if i didn't already have one.
Are you sure it's taking its signal from front left? I am going to have to dig up the wiring schematic, I thought sure the yellow/yellow w/ black tracer was the sub wires on the previous gen trucks.
If it is truly taping the front left I'm wondering if it would sound any better/different tapping into the Bose subwoofer vs taping into the front left speaker wire??
I'm pretty sure it's from the right, not the left. Try playing around with the fade to see if the sub volume changes. I don't know how well tapping the Bose sub wires will work because i believe the Kicker's amp filtering has been tuned to tap off the full range-speaker. Truck wiring diagram below.
I have a 2016 silverado, when I was young I always had custom systems.
I did miss the bass when I bought the truck, rather than mess with electronics that ties the the back, I opted for the kicker kit.
I is a night and day difference!
Money well spent, very easy to turn bass up or down with the menu button.
Install is straight forward with instructions.
Whether you like country, rock, or hip hop it definitely improves the overall sound.
don't bother with the kicker bullshit..JL audio makes a stealth box...custom built for the truck, I would recommend this over all options available..keep in mind you have to run power and ground to an external amp and spend more dead presidents lol
The JL box, while undoubtedly far superior, is 3 times the cost just for the box. Then you add an amp, and the wiring and your probably at 4 times the cost.
In addition to the cost you have to consider the rest of the system. Ince you add 2 12's with decent power what do you do about the highs? Your either going to have to turn the JL way down or start replacing door/dash speakers and adding amps to power them.
I'm with you on this one. I have no doubt the JL will rattle your teeth loose but for me, it's all about balance. And as you said, it's also much cheaper.
As promised, pictures of my install and some notes.
1. I couldn't remove the right kick panel on my truck. Seems stuck so I had to use another ground point. There is a ground point (long bolt) behind the big blue plug in the fuse box. Also had to tap-off in the passenger sill because of this as shown in the pictures.
2. The install guide said to tap-off a twisted yellow and yellow/black pair in the wire bundle. I couldn't find this pair in my truck. The closest i found was a twisted yellow/gray and yellow/black. I'm a engineer by trade and these 2 sets of wires are not the same. Nevertheless, i contacted kicker support and they suggested i test the yellow/gray and yellow/black pair for dc and ac voltages. This worked. Not sure why the coloring in my truck is different. I have confirmed this is indeed the right front speaker by fading completely to the left and the bass goes away.
3. The knob wire is long enough to route through the cable channel. This is what i did. Zip-tied everything together. Stuck the knob under the trailer brake with 3m vhb and it fits perfectly. The knob wire routed cleanly.
4. Didn't have to cut any carpet or floor mats as mentioned in the install guide.
cable_channel_rear.thumb.jpg.b847d68761b4ba98b0502178afb0106a.jpgtap.thumb.jpg.0c1a6152477a604c05807ffb056aaabf.jpg
The carpet cutting is for hiding the wires underneath and also a cleaner install. I initially did the same but after I put something in the small storage area and pulled the harness up I decided to cut and route under to avoid this in the future. I also ran the volume knob wire down the driver side and mounted the knob low on the driver side so it cant be seen. That knob is an indicator that there is a sub in the truck and don't need anyone thinking it's worth breaking into.
Also, for anyone running and android based OS phone, there is a 10 band EQ under advanced sound settings. Additional tuning can be done to the sound this way.
Edited by Smrtasp
Spelling
So I received mine today and tossed the box into the truck just to have a place for it right now. I know the instruction say to cut the rubber floor liner but man I really dont want to do that. Has anyone installed without cutting the liner? Any issues? Did you install without cutting only to go back and cut afterwards for any reason?
See my post and pictures above. Didn't cut anything. You can lay the wires on top, route them behind the seat anchors, zip tie them nicely and it's not messy. You will not be able to remove the floor mat easily if you don't cut it but i'm ok with that.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
