Make tow mirror parking lights blink with turn signal
It's probably been discussed but I'm having a hard time finding it. I want to make the amber parking lights in the side mirrors blink with the turn signal. I thought they did until going to work this morning and seeing a reflection while in the turn lane. I saw there's a wiring kit you can buy but there's gotta be an easier way. Are there pins in the bcm for the turn signals and the mirror lights? Is there a way to jump the pins using a diode? Really don't want to pull the mirrors off and splice any wires
Sent from my SM-G955U using Tapatalk
  • 1 month later...
If you have tow mirrors that are functioning to OEM Factory Specs, I now have a PnP Adapter that converts your running light into a dual function running light/turn signal.
This does have the prerequisite that your tow mirrors have fully functioning running lights, cargo lights and turn signals. If you previously purchased a conversion harness, this should work for you.
Adapter set is $125 shipped anywhere in the US.
They simply plug in between your mirror plug and the door harness plug.
My 2017 SLE 2500hd has the amber lights in the tow mirrors, everything works perfect, this adapter will have the running lights in the front part of the mirrors flash with the turn signals?  Way cool, this harness is in the open door hinge are? Very interested.
Yes sir. If your mirrors are functioning like factory (no non-OEM modifications), it’s simply PnP. It plugs in between the mirror plug itself and the door harness plug. This will require to remove the door panel to access the mirror harness connector.
PM me to order. If you can send me an email as we’ll my email is [email protected]. A pic of your glove box RPO codes and pic of the mirrors would be great.
Thanks!
Phil
Just now, gearheadesw said:
That is so cool, thanks Phil! You’ll be hearing from me soon.
Sounds good.  I included my email in the comment (just edited it).  Look forward to hearing from ya!
You make these? How on earth did you figure that stuff out..... SWEET, I’ve been looking for exactly this. Truly stupendous, thank you.
7 hours ago, Icutmetl said:
Where is this harness located? Does the door panel have to come off?
Yes.  Door panel comes off.  My harness adapter goes in between the mirror plug and the door harness plug.  Basically, unplug the mirror from from the door harness and plug mine in between.
  • 4 months later...
Thanks!
Phil
Hey Phil, I’m going to get the pictures of the codes in the glove box, and a picture of my mirrors. I’m going to yank the door panels off for some new speakers, so now is the time for this great mod, I’ll PM you like tomorrow. Thanks.
Sounds good.
Super easy mod, thanks to Phil! It took me less than 30 minutes to put these in!
My 2017 Silverado 2500hd WT 4x4 has OEM tow mirrors. Are the factory standard OEM tow mirrors “turn signal blinks in the mirror” only with just marker lamps on the front side of the mirror? I truly don’t know?! If so... is there a possible way to make/get the front side marker lamps to blink/act as a signal light along with being marker on the front of the mirror on my particular year model? I really love that particular feature on these newer trucks. However, I think that my truck probably didn’t come with that feature as it is a WT version. ??
I implore someone who is way smarter on this stuff than I to please give me some feedback so as I can move in the right direction in order to possibly ad that feature to my truck.
Thank you!
P.S. @pgamboa
Mr Gamboa, I’ve watched you work via your YouTube channel. Amazing stuff! I tip my hat to you, sir! I’d love to be your apprentice (if it were ever possible) as I do enjoy tinkering/upgrading my truck. Unfortunately, the electrical aspect of it has not/is not my strong point.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
