2019 ground clearance?
I own a 2018 Z71 and while bored I found myself looking through the specs for the new 2019 trucks and noticed that the ground clearance on these new models is almost an inch less than on the 2014-18's at about 8 inches unless you get the trail boss. Does this sound right? Just struck me as odd that Chevy would lower the ground clearance on these new models instead of raising it. My 18 sits pretty low as is at 8.9 inches of clearance and I want to level it and upsize tires eventually just to get the front off the ground a bit more. My only thought is that they're trying to upsell the 2 inch factory lift? Or is it for better mpg's? Any thoughts?
They are definitely bigger than the last gen.  I saw a K2 and a 19 sitting next to each other today, both LT models and the 19 is much taller. I dont know the exact specs but this was from looking at it
And the '19  crews are taller as well as lower......in the GM published dimensions, compared to the '18's.
(at least the crew std box)
First thing I noticed was how much taller the T1 is over the K2. They seem to have raised the cab a bit on the frame to flatten the load floor in back. Bed sides are also taller.  Ground clearance might be the same or less, but in every other measure the T1 is much larger.
I believe the AT4 has ground clearance of 10.8 or 10.9 with the factory 2" lift which would be around the same ground clearance as the K2 in a non AT4.  The T1 is wider and taller than the K2.
I think pushing the front of the cab forward to make that extra 3" of room behind the front seat has a lot to do with it.  If you look under the hood the engine sits way back under the windshield now.  They probably had to lift the cab floor to fit the engine under there.  I probably won't even try a Roots blower on this one, it was already annoying enough on the older ones.
Good point.
I’d like to procharge some day after the warranty is gone. But the way things are going nobody is ever going to have a tune for the blower install anyway.
what defines the "ground clearance" anyway? is it the space under the rear diff? or how much snow I can drive through before the plastic valence becomes my second plow?
I thought the front valence was the lowest point, and that could easily be removed or trimmed to some degree.
There  is an additional air dam on the new trucks to reduce their drag coefficient and increase fuel economy. Possibly this could be removed and stored until you decide to sell the truck.
http://gmauthority.com/blog/2018/07/2019-silverado-aero-enhancing-air-curtains-feature-spotlight/
Approach angle is more of a consideration than the clearance under the center of the truck in most situations I encounter, and this is where the air dam would be a concern.
My old K2 and and new TB T1 side by side. TB doesn't have valence on bumper so ground clearance and approach angle should be better3203792227fb8409f73bcdc84d5ceb0e.jpg
Sent from my Pixel 2 using Tapatalk
These new trucks just look so much bigger than the K2s. With GM keeping the same MPG and bringing down the weight 300 to 400lbs it is impressive. That's where all of the r&d money went that didn't go into the interior.
Sent from my ONEPLUS A6013 using Tapatalk
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
