On 3/31/2019 at 5:24 PM, Sotally Tober said:
Here are some pics of my RST.  The lower bumper is from a LTZ or High Country and we simply painted the chrome portion summit white and reinstalled.  It's still a work in progress (also dirty) and as you can see the lights are still missing.  I had fast headlights remove the orange and replace with clear lenses.  I will be doing a full build thread within the next 2 weeks.  Lots of mods to share.
Do you have the part number for the lower bumper for a LTZ or High Country?  I cant seem to find this part any where online
  • 4 months later...
On 4/12/2019 at 9:57 AM, lebag335 said:
Chevrolet accessories sells the letters for $150 and you install yourself. I went to a local auto trim shop and had vinyl letters added to my tailgate where it's stamped CHEVROLET.  Looks amazing!  Cost was $99. My truck is an LT Trail Boss so I don't have the grill letters, but same concept applies.
they have those kits for tailgate all over ebay for cheap ( think mine were like $20)…..the front would just be a colored plate I would think to stick behind the grill
Edited by Dunn
  • 6 months later...
Where did you get the LTZ or High Country bumper to do this? Also how much did all of it cost? I want to do something like this to my RST.
  • 3 months later...
  • 3 weeks later...
  • 1 year later...
On 10/7/2020 at 3:12 PM, Flatblack83 said:
Here's mine, not a trailboss but with the gm black grill and painted bumper.
Beautiful truck!  What size tire/rim package?
On 10/23/2020 at 10:54 AM, motogp04 said:
Finally got my bumpers back from paint...love them...here's the front, I literally just put it on.  Rear incoming shortly...
protect the bumpers ( Front ) 3M cleat flim . I did my Black truck - bumpers, grill , 10" strip front of hood , mirror caps.
On 3/30/2019 at 8:13 AM, qwank said:
Has any one done this yet, paint or wrap?  I'd like to see one with just the bumpers done, and also with the bumpers and grille done.  I think they would look a lot better that way.  They look too much like a work truck from the factory, especially the Custom trim.
I went a different way around it, got the custom instead as things already color matched, then did a boss plus treatment myself 😉
At least there's a visual of what it may look like if you color match.
image.png.ce85a92e394a857fb89f3f544e7dc3f4.pngimage.png.8b68bd6921c8c234f287840793a38423.png
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
