Recently purchased some Stihl HP Ultra 2 cycle oil.
I noticed it no longer has fuel stabilizers in it.
When did this happen?
Stihl getting cheap?
Price didn't go down of course.
  • Haha 1
I've been running it and haven't noticed any difference in shelf life or performance differences. They still require the purchase of it at saw purchase to extend the warranty so they must have faith in it...currently.
Sent via Morse code
Does it state that it doesn't have fuel stabilizer in it?  To me that is a bad thing.  I know AMSOIL added stabilizer to there Saber 2 cycle a few years back.
$32.00 a gallon . I'll mix my own.
Edited by tbarn
I use it when the saw will be sitting up for a while. It doesnt varnish like gasoline.
Sent via Morse code
I always add a little SeaFoam to the fuel mixture used for my Stihl 2-cycle chainsaw, Weed-Eater & Blower/Vac as well as my '94 Lawn-Boy Gold mower fuel mix.
Seems to help.
I emailed Stihl about this.
There reply,
Hello Mr. XXXX,
We are in receipt of and thank you for your e-mail.
Stabilizer was deleted from the refining process of STIHL HP Ultra engine oil because stabilizers only have a marginal effect regarding shelf life extension of mixed fuel. Before modern fuels were augmented with the additives currently used, stabilizers were a much more effective product regarding extending the shelf life of gasoline. Nowadays, stabilizers only extend the shelf life for a matter of days rather than weeks or months.
Thank you again for your e-mail.
Best regards,
Wayne Lemmond
Technical Service Representative
STIHL Inc.
  • Thanks 1
I got hooked on the $32 a gallon gas for awhile. Then I went to the station and store, bought my gas, oil and some seafoam and made my own for like $4 a gallon. Drain them over the winter.
I use the Stihl Motomix for mine. No fuss no muss. I buy it in bulk for all my Stihl equipment.
I mix my own with premium gas, 91 octane here and Stihl HP 2 cycle oil.
Run the saw out of gas when stored.
Never had a problem.
Use the same mix in my leaf blower that gets used year round.
Used to blow off deck when light snow and clean driveway to keep from tracking stuff into house.
Also they run rich here at 9200 feet.
I don't let them bog down, full throttle.
Edited by diyer2
  • 1 year later...
I don't mind they deleted fuel stabilizers but the price is still too high as for me. I prefer to use something else instead of Stilh HP Ultra. Unfortunately, I have some troubles with my chainsaw as it regularly wedges and produces weird noises that make me feel uncomfortable. Almost the same problem I had with my scroll saw which is a great tool too cut various materials, not just wood. Lucky for me, I read an interesting review about best scroll saws today on https://mitersawjudge.com/best-scroll-saw-reviews-and-buying-guide/ shared by Paul Sellers (you should know this guy). Probably going to buy one of them because I need this tool in my house.
Edited by IamPhenomenal
  • Thanks 1
For 40 years of ROW work carrying crews to support my clearing machines with weeds eaters and chainsaws. That were used for fence lines and areas not accessible by machine. We used the proper mix and corresponding cans so no mixing mistakes were made. Later just using the Amsoil mix when available. After retirement and keeping an old saw for limited service. It’s probably at least 20 years old. I can say without a doubt the premix they sell at stores like Home Depot are worth the money. The gas in my saw tank right now is at least 2 years old. So is the qt can next to it. I can say without a doubt I can start my saw in 5 pulls after priming. And it’s a stihl.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
