Exhaust doesn't make sense
I'm having a really hard time understanding how everyone 100% believes and accepts as fact that Borla makes the GM performance exhaust.  If that is in fact the case, why did it take them this long to come out with a cat back system with their brand on it for the 5.3 and still don't have one for the 6.2?  Seems like if they really did make the GM Performance, all they need to do is switch out the muffler out for one that has their name on it and poof it's a borla system.
Also, being that I have the 6.2, I was kind of interested in the Flowmaster setup, mainly because it's one of the only ones available.  What I don't understand about that is why in the world they would go 2.5" from the muffler back when that's smaller than stock.
You must be looking at the 5.3 exhaust since the 5.3 pipe diameter is 2.75 so they could either reduce it or go to 3 inch.  The 6.2 L I believe is 3.5 inch exhaust so it could also be a typo.
Rumor probably persists because Borla makes the K2 performance exhaust for GM, with a GM part number on it and everything.
I seem to remember someone on here asking Borla about the T1 GM exhaust and they confirmed it was theirs, but who knows.
Personally I don’t care. The price difference between the GM, and the entry level Borla using stock tips is a wash. And I’m happy I went with the GM because it sounds great and I’d still be waiting for any other brand to make one.
Not sure what the tailpipe size after the “Y” is on my GM exhaust, but it’s a single 4” out of the muffler before it splits off above the axle. The Flowmaster looks to a dual outlet muffler instead. Two different ways to do the same job.
The T1 Chevrolet Performance branded catbacks are made by Corsa.  GM did this on the single side exit Chevrolet Performance K2 exhaust kits as well (they even say TMG Performance, the parent company of Corsa, right on the box).  Note that they are warrantied by GM and not the manufacturer.  So Corsa supplies them for GM, GM then sells it as a GM product, with a GM warranty.  They build them with the Touring muffler.
From my email with Corsa on the Chevrolet Performance branded exhausts, while I was shopping on my 2019 K2:
Quote
The kits they get are the Touring, and the mufflers can’t get swapped out for the GM performance exhausts that we do.
On the GM/Borla, they were made by Borla, developed with GM (hence the AFM flapper) and then warrantied by Borla, and marketed by GM as such.
Regardless of whether Corsa or Borla make them, they both just now have come out with their own cat backs and neither has one for the 6.2.  That makes no sense.  They obviously have the design
I just ordered the Afe exhaust for the 6.2. It is a 4" inlet and dual 3" outlet. I figured you cant get much more flow than that. The price is decent at $725 attaching to the factory tips. They have other tip options available also.
My GM 6.2 exhaust is definitely Borla made not Corsa. Easy to tell by the muffler design and the fact that Borla said they made them.
I would guess GM made exclusive rights for the performance exhaust for “X” period of time before they could release their own branded exhaust.
If you haven't looked under there yet it doesn't actually attach to the factory tips. Just sits in the middle of them freely.
Post some pics and videos when you get it installed
Sent from my Pixel 2 using Tapatalk
I am very happy with the GM performance exhaust.  The AT4 I ended up getting had the performance pack with the intake and exhaust, bonus was it got rid of those annoying flapper valves too.  No drone and quiet when not on the throttle.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
