On 4/24/2019 at 10:04 PM, destrada127 said:
5k miles here too on my AT4 and I've had no issues whatsoever6678ceb6aa5bbd0592e73b1e71ad0f4a.jpg
Sent from my SM-G975U1 using Tapatalk
What size wheel/tire are you running and what type of front bumper is that?
That is an old pic. I was running 35/12.50r20 in that pic but now I'm on 37/13.50 on 20x9 -12 on 4"rough country lift. The bumper is addictive desert designs stealth fighter15d1c9aff2c6567e3197c6f52f1802a8.jpgd059a87e695085c804f2be1da63f131e.jpg
  • 4 months later...
After a thousand miles with the Readylift 1.5” leveling kit, I’ve noticed noise on my drivers side at low speed. It sounds like a knock. It doesn’t happen every time, but enough to be concerned.
is it during rolling, dips, or bumps....  a little more details.   Maybe loose strut mount hardware, either upper or lower.  Not to much is messed with during install so tracking down issue should be easy, unless kit caused new problem.
I have approx 10,000 KM's on my 1.5" leveling kit. (6,213 Miles)
2019 AT4
No issues at all. No sounds, no creeks, no issues.
2019 AT4
What kit did you use?  My AT4 is currently at the shop having Fabtech 1.5" installed.
I'll have to look up the paperwork when I get home tonight. I don't remember.
  • 3 months later...
I bought the truck new from the dealer with 285 65 20s on it.   Not sure what parts they used but the service rep told me they used a spacer up front.  I measured the front and rear heights one time.  If my memory recalls there is about and more height in the rear.  I'm not a mechanic so I don't know what that translates too.  Screenshot_20200203-110448.thumb.png.48f5743b49b7609262905081d266b559.pngHere is a pic.
26 minutes ago, RLCC said:
What tires did it come with
NITTO Ridge grapplers03509774-0F15-4672-BE23-665197ED162B.thumb.jpeg.eb32a5232a785371fe3fd7c636fffe98.jpeg
  • 7 months later...
Hi when you add the leveling kit will 20x10 wheels fit pretty good with no hitting the mud flaps. I have a 2021 at4 and bought 20x10 fuel wheels with a 285 5520 tire not that big but it still hits the flaps. It’s annoying. I wanted a bigger tire but if these hit.
    tblt44
    tblt44
  • Who's Online   3 Members, 0 Anonymous, 524 Guests (See full list)
