On 4/13/2021 at 3:07 PM, BigKev said:
Anyone know what the specs are on this RST? Im guessing RC 3.5” or 4” and either 295/60-20 or 35x12.50-20 trail grappler. Thoughts or ideas?
Sub’d I have the exact same color truck but with the Duramax, I’d love to know the tire size and how much lift it has front/rear!!
Go back to page 2 and look at Jmike's post. Similiar look using RC 3" suspension lift and 35x11.50rx20.
On 1/21/2021 at 3:27 PM, SILVER SLED said:
The front spacer is a ProComp I got through American trucks.   I tried to copy the page but couldn't.  Here is the part/item# info.
S111877 - Pro Comp Suspension 1.50-Inch Leveling Lift Kit (19-21 Silverado 1500)
Item #: S111877
Sorry if I'm asking a question that's already been asked and answered many times but, anyone have a list of torque specs or point me in a direction to find them? In particular;
Upper Strut Mount Nuts -
Lower Strut Mount Bolts -
Upper Ball Joint Nut -
Sway Bar End Link -
Thanks!
Has anyone installed the fox performance 2.0 kit? Considering buying  it and would like to know about ride quality and what clips y’all are using to level?
Sway Bar End Link -
Thanks!
Sorry, I don't know.  I had mine installed and assumed the got the bolts at least good n tight.
I’ll answer my own question. Installed the fox 2.0 kit which raises the front 2”. Looks great and rides outstanding. Big improvement over stock.
Here are the front torque specs for a 2021 rst 4x4 3.0 1500 4 door, rest of specs attached below in Doc
here is axle tighten specs, other specs attached in document
nt Wheel Drive Shaft Nut
Callout Component Name [Component Quantity] Single Use Fastener/Component Thread Locking Adhesive Required Specification Procedure
Metric (English)
1 Front Wheel Drive Shaft Nut Yes First Pass:180 Nm (133 lb ft)
Second Pass: Reverse 45 degrees
Final Pass: 270 Nm (199 lb ft)
Front Wheel Drive Half Shaft Replacement - Left Side
Front Wheel Drive Half Shaft Replacement - Right Side
21 torque spec 1500 4x4 front (1).pdf
  • 5 months later...
    JJ_Denali2020
    JJ_Denali2020
  • Who's Online   2 Members, 0 Anonymous, 808 Guests (See full list)
