On 12/11/2025 at 8:49 AM, customboss said:
Go outside more and post less. Good medicine. Works for me.
How about I post less and you just stop posting and be good for you word. :rolleyes: (Though you quit this place) 😏 Please!
  • Thanks 1
At least I post things that matter to the general reader. Unlike you posting to read yourself bloviate. Merry Hanukkah.
Edited by customboss
4 minutes ago, Atlas said:
Winter?
It's going to cool down to a high of 80 today 😎
Desert life
Oh you are living in the ugly part of Washington state ! 😊
LOL no. I actually like that desert, though.
Visiting the area outside of Palm Springs CA
  • Thanks 1
88 here in my part of Tx on Saturday. 62 today. Starting Tuesday a week of 80+ days
Rained all day with temps in the 50's. Then tornado warnings. Tornado touchdown south of us. Now 35 to 50 mph winds until tomorrow night. Temps head to the basement, -22F windchill right now and temps to go 8 degrees colder in a few hours. Quite a mix. Cape Horn weather. LOL
48 this morning wind 25 gust 45 .... yesterday was 90 ....  ahhh good old South Texas 🙂
we lost close to 10 degrees at 5 am this morning in no more then 30mn
Edited by Homer1959
It'll be a cool 72 degrees for a high today in the low desert. Wish it would be like this year round, but then, a lot more people would live here.
High of 20 yesterday, light snow, just a dusting.
When from 80 yesterday to a high of 56 today. Down to the low 30s tonight. I don’t mind a taste of winter. It will edge up after. That’s one reason I live here. This time of the year’s weather.
Edited by KARNUT
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
