Need some moisture bad !. Never had a winter like this in many years.
  • Thanks 1
We gonna burn 🔥
6 inches 12 degrees.
-2 F this morning. -23 F wind chill. An inch of new powder. Dizzy said, "Go back to bed. Leave my old bones alone". :crackup:
  • Haha 2
-17 to start the morning. Wind chills -39. Trickle chargers on everything overnight. Took all that my original 2018 battery had to give, but we’re up and running for the day. And probably safe for another year. Don’t think we’ll see weather quite this cold again any time soon.
It’s in the 60s here currently. Snow, sleet, ice are coming potentially. The 20s are projected for the low possibility staying under freezing for a whole day Sunday to Monday. The freak out is engaged. My generator is ready just in case. Goodness gracious.
It's in the high 20's for lows here in the upper left. Not uncommon for this time of year.
Y'all down south...make sure you don't bust all your PVC piping in this next big freeze that supposed to be on the way.
Woke up to -14 F and windchill at -36. Got a whole 7 degrees warmer and the high not just for today but the next three we are being told. Dog is taking a hot second to do his business and limping back to the house. I don't let him off lead nor outside alone. Short hair and thin ears.
About -22F this morning, got a whole maybe -9F today depending on where you were. Was basically -15F all day for me and the low is -20ish again tonight.
Work truck gelled up within a half mile today, limped it to the service center right next door. Way too long waiting, a new fuel filter later and off I went into the sub-zero temps again. Happens every single year even with treated fuel.
Currently 6 degrees not taking into account the wind chill.  I am so over winter.  Supposed to get 12" of snow saturday to monday.
400 miles south of your position (  Mission Tx)  72.
The coldest day will be Sunday and Monday  50 days / 28 at nights...  sorry guys ... 🙂
I like mountain life.
I’m on the line of less ice and temp change over. In most cases the bark is more than the bite. In this case there’s real danger in some areas.
Edited by KARNUT
