25 minutes ago, REDOO2000 said:
Just installed some bilstein 5100
Boot up or down? Writing looks like boot should be down...
I’m driving into work tomorrow so I’ll see how ride is affected.
Where did you buy them from?
Amazon 72$ each
On 5/13/2019 at 1:52 PM, Sierra Dan said:
You know me all to well Andy! :thumbs:
Because the internals can give way at Any time rendering them worn, blown, useless or whatever term is appropriate.
Here is a picture of the Rancho shock at only 5300 miles.
If it looks like this on the outside what is happening on the inside?
And a short video of what happens to them when they fail.
Nothing more than a pogo stick which is exactly what mine turned into.
This is what they look like with 24k. ?
OEM Shocks are garbage.. I replaced mine around 40k on all 4 corners..
This is what they look like with 24k. [emoji90]
Mine look worse at 25k
One has almost no white paint left
Definitely a smoother ride this morning
Felt a lot less bumps
I’ll see how ride home is
how long did it take to install?  (you just did the rears, right?)  I've never done it, but it seems much more simple than the fronts...
Install for the rears might take 15-20 minutes. Very basic tools ratchet and a wrench and that's it!. 4 bolts total.
Sent from my SM-G960W using Tapatalk
do you even need a jack or just compress the shocks to install?  that seems really easy...
No jack
Just compress by hand
No Jack required. I did mine right in the driveway with a wrench and ratchet. Forget the size now. Compressing the shock can be tricky to hold it with one hand and slide the bolt through. As for the fronts I had a shop do that for me.
So now that you have had them on for some time, how overall satisfied are you with the bilsteins?
I am interested as well would like to swap mine. Thanks
Very satisfied with bilsteins
Night and day difference
    Charly
    Charly
  • Who's Online   1 Member, 0 Anonymous, 3,523 Guests (See full list)
