Ok I hooked up a trailer to my 1 month old 2019 Chevy Silverado today for the first time and had no trailer lights. Hooked up my second trailer and also had no trailer lights. Connected both trailers to my father-in-laws truck and both worked fine. Checked both sockets the flat 4-pin and round 7-pin and had no power at either one. Anyone else had this problem?
Nope.  Take a look behind the plug and see if the harness is disconnected.
ok I would get a test light 12v and verify at your truck plug what you do have. Check the turn signal left and right and running light.  Definitely check as BSHORT said the harness. If the fuses are good then you should have power back there, check the ground that could keep it all from working to. Since it so new you could take it back to dealer also
Looks like the harness is connected to the sockets and have already tested for voltage with a multimeter nothing on running lights, either blinker or brake lights. Got an appointment with the dealer tomorrow. Probably something simple but got me stumped at the moment.
There is a bulletin out about trailer light control module. Big thread about this under other heading. Guys originally thought it was related to cold weather. It shows up also as trailer disconnected message. Problem has to do with lights drawing too little or too much amperage. Took me a long time to get mine sorted out but the reprogram should help.
Took it to dealer and they had to order a “module” for it. We will see next week if that fixes the problem. Never thought there would be such trouble to just hook up a trailer and plug your lights in. It’s really no all that complicated until technology gets involved lol.
Mine has been in the shop for 2 weeks with the same problem. They have changed two different modules and still can’t figure it out.
Any luck on yours yet? Called again today and still no part has came in for it. Truck is 3 months old and still unable to pull a trailer. Getting to be a little ridiculous
my 2019 LTZ also didnt power lights at first.  Even though the trailer brakes worked. Later it said that the trailer was disconnected.  I changed the profile on the 'car hauler' and
removed backup lights.  I dis and reconnected the 7-pin connector then 'added' a trailer.  The truck prompted me to test the trailer lights and it looped through testing left, stop,
right lights and sure enough the side markers were on as well.  Havent tried it again but will.   dont recall now if I set it to tow/haul mode.  Neighbor said his 2011 ran used to report 'disconnect' and 'connect'  while driving
all the time.
I have the same problem with my 2019 gmc slt all trailer lights work except running lights. I tried trailer with daughters ford they worked fine. no power at running light pin. went to dealer they said trailer is not compatible with truck said it was a pulse width modulated system in truck and I needed a 55ma draw from trailer lights to make it work and need a load resister on lights. I think load resister is needed if you have led lights since they don't draw enough. bought a curt plug # 57003 adapter which has resisters built in, it didn't work tried truck on friends trailer,  running lights worked fine,  had truck tested at trailer place he said it was fine. Tried connecting an old headlight to running light pins and it light it up. also have a trouble call on truck trailer screen. here is the strange part when trailer is connected and I turn lights off then on running lights go on for I sec then off, every time I turn off then on same isec blink of lights. Wondering if I have too many lights on that line and the heavy draw kicks lights off since they are not led.
Edited by littlethorn
Maybe your ground isn't hooked up on the trailer.  These trucks have a hard time getting power back to the trailer through the hitch.   Mine would reset and show connected/not connected.  Took the ground wire on the trailer and made it grounded to the harness, so it completes the path not through the hitch.  Worked for mine anyway. Good luck.
Ken
Has anyone with these problems tried the trailer light module reprogram I mentioned earlier. It helped my truck a lot. I believe that it widens the acceptable amp draw of the trailer lights substantially. My running lights were drawing too much so it would shut down so I swapped all trailer lights to led. Then my brake a d signal lights were not drawing enough so it shut down so I added the resistors. Now after reprogram and new lights everything works as it should. Also eliminated the trailer disconnected message that used to show up frequently. A combination of new lights with the proper amperage draw plus the refresh has almost completely eliminated these problems.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
