Car seats
Anyone have suggestions for rear facing car seats that fit well in the double cab!
Sent from my SM-G960U using Tapatalk
I was able to make a Maxi-cossi fit in my double cab. There aren't many that will rear face on the passenger side. You need something semi narrow and short. A large car seat like the Graco 4ever wont fit. Wish they would have put the latches in the center seat. I ended up rear facing on the center seat with the belt. The diono is a great forward facing car seat, but didn't fit well rear facing.
Sent from my Moto G (5) Plus using Tapatalk
Good luck with your search!  I had an F150 Supercab and with a Recaro rear facing seat for my first son.  My wife was literally on the dash board.  That car seat was massive.  Super safe but really inconvenient.  Hence why I own a Sierra crew cab now.   I think Recaro stopped making seats.
Costco usually has some decent seats for sale.
The question you have to ask yourself is how many kids are you planning on having and how long are you planning on keeping your truck. I would have loved to buy a crew cab, but I didn't want to spend the money for a 1 year inconvenience. My wife needed a new car and mine was only 2 years old. We dealt with it for just over a year and flipped her around as soon as she was big enough. This was only really an issue between when she out grew the bucket and when she could be forward facing which was about a year. Now it isn't an issue. The belted booster is awesome for small backseats.
Only one year?
I'm pretty sure the new "guidelines" recommend keeping the rear facing car seat until they're 15 and can have a learner's permit.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Only one year?
It is a booster seat till they are 15. [emoji3]
We left her backwards facing till she was 2. It was only about a year between the bucket and forward facing.
I have two Britax Marathon type seats from Target and Amazon.  These are relatively big and I dont think they'd be a great fit unless forward facing.  Rear facing they would possibly fit, but your wife will be resting her elbows on your dash.  The back of the car seat touches the passenger seat headrest, but the passenger seat is in a normal comfortable seating position with ample leg room.  This crappy picture taken in the rain is of my crew cab.
The seat in the center might be your best bet as you can have the back hang into the gap between the seats.  If theres no anchors for the middle, could you use the inner anchors from either side seat and secure it that way?  If I use the anchors only in the rear right seat like pictured, I still have to use the top strap to keep the seat secure (you can see it in the picture attached under the passenger seat rail).
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
