$165 is an ok price. My dealer charged  $235 to install and flash. I used my rewards coupon from buying the truck toward the install.
Nice to have them in and working. When you turn off the auto lamps and hit the fogs, just the fogs and parking lights come on. Looks good!
On 2019-07-02 at 5:35 PM, TBHiker said:
I spoke with the shopchevyparts where I purchased the kit. They told me that many dealers are making the mistake of programing the BCM the old way instead of calling a specific number and giving them the VIN and code included in the kit. Hoping that was is the issue. I will be going back next week.  Hope you have better luck.
Do you happen to know the number they are supposed to call?  I’m betting my dealer is still doing it the “old” way, which is why my dash light doesn’t come on.
  • 4 months later...
So the Chevy dealer closest to me has had my Sierra for now 7 hours and have been unsuccessful in getting the fog lights to work. I did the install of everything except the depinning of the wire on the UEC and connection of the harness wire.
I forgot to provide them the programming code that came with the kit, but they said they were able to obtain one from GM. Even so, they can get the indicator on the dash to illuminate but not the lights themselves. Seems others have had the same issue. They have already charged me $130 for the programming and another $50 for labor in trying to rectify the issue. They are tracing wiring apparently; something I told them wasn't necessary. But no one wants someone else to tell them how to do their job.
It's now Thanksgiving eve and they want to keep the truck till Friday. I told them I'd rather pick it up because I was planning to get a Xmas tree Friday AM. They said I would have to pay the $180 to take it with nothing working. What a deal, right!?
Does anybody else that had a similar experience have specific instructions on what to do to get this fixed? I'm confident it's an issue with the programming and they are confident they know how to do the programming.
Thanks in advance.
Edited by swing4terps
An update. They finally got the lights to work. According to them, “programming” requires that they install a jumper wire. I took a quick peak at the BCM and saw nothing additional, so I assume the jumper is related to the UEC.
I was a bit surprised to hear this and frankly it doesn’t sound right, but if the lights work I guess I don’t really don’t care.
For those of you that did this, what did you do with the B3 wire that was in the UEC already? The instructions seem to say to just take it out and tape the end with electrical tape? It seems like this wire should be doing something?
I also had the brown/white wire at the BCM already so I did not do the jumper wire through the firewall.
Thanks
I just had the dealership install the oem fog lights on my 2019 Trailboss. Looks like I am running into the same issue as a lot of people. The lights work , but no fog indicator on the instrument cluster.
From what I am reading (correct me if I am wrong) it has to do with the programming of the BCM? I want to make sure when I go back to the dealer I don’t get jerked around.
Any input would be appreciated.
Edited by IamEnzothebaker
Thanks
What did you do with jumper wire if you have it laying around I’ll take it if your hands if you want to sell it
Anybody with the extra jumper I’ll take it off you hands dealer did a real crappy job with mine please let me know thanks
  • 4 months later...
On 7/11/2019 at 4:32 PM, sse1990 said:
In the attached pictures, the small brown connector is what is in the BCM under the dash.  Mine already had a brown/white wire so the instructions said I didn’t need the jumper.  In the other pictures, the green connector is what you open and the wire gets installed from underneath.  I had to remove a wire from B3 position to be able to install the wire from the kit.  I did not have to remove the wire from C3 since that is the brown/white wire already installed.
Also I just tested the pre-installed brown/white wire and I have continuity.  So I do not need the single jumper wire provided in the kit.
On the UEC, how did you pull the green "body 2 connector" so far apart to be able to see underneath it/access it? According to your photo here, mine is pulling away maybe 1/3 the distance as yours.
If the fog lamp indicator did not light up previously and now does, they programed the BCM correctly.
  • 3 months later...
I'm fighting the same thing right now. Dealership was unable to program the BCM after three hours so I left it with them. Is there some instructions or tech help I can refer them to? I installed the lights this weekend and the one jumper wire running to the switch was not needed as I already had that wire in the BCM connector. I did manage to lift and remove the B3 pin and get the new wire put in place of the existing wire. Hoping they figure this out quickly.
BTW - on the UEC and gaining access to the underside. Yes it’s difficult. I had to remove the piece that holds the split loom in order to turn it for seeing under.
You have to remove that white lock insert on the left side of the connector and use a two prong tool to push old connector out if ones already present. New wire fits fine. Just reassemble the connector lock. The one area I struggled was the large split loom was nearly impossible to open and suck in the new wire and loom. I elected to take a Dremel tool and slotted the bottom mount to allow the fog light wiring to exit the bottom of the UEC and not try to shoehorn in the existing cable. That way the split loom holder can go back like original and you support the lower wire harness properly.
Update. Only took them 2.5 days to get it done! I now have fog lights and yes the icon on the dash lights up! Winning - finally!
I just installed an aftermarket set of OEM style foglights on a 2020 silverado.  I just simply ran the power from the battery to the relay, ground to a bolt on the body near the fuse box under the hood and used a fuse tap on the running light fuse, connected to the relay switch wire.
They come on with the running lights and turn off with the running lights.
Edited by Tim Cogley
  • 3 months later...
I came across the same issue as you. Did you find out what that wire controls?
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
