Speed limitation deleted?
Mine stops at 112. Yes, I tested it. No, it was not on a “track”... it was on some empty divided highway in rural Texas.
Same here! 112-113 is what I saw.
I’m assuming trail boss is limited at 98 due to the “lift” and all terrain tires
On ‎7‎/‎15‎/‎2019 at 9:54 AM, GTPprix said:
I have hit the 98 MPH limiter passing someone that was doing ten under in the left hand lane here where our speed limits in some areas are 80 that being said... keep your eyes peeled... we'll likely have something you'll like very soon :)
Soo... you're gonna have some sort of speed governor  eliminator soon?  That would be awesome.
Already have that done... trying to get a bunch of other stuff to go with it (for the T1's!) :) I see you've got a 2018 according to your profile if thats the case its already done. Check out the WAMS Spec BCM on our site!
I already have my speed limiter deleted, but I will definitely check it out.  Thanks Chris
Was just getting ready to message you to see where you were with the T1 BCM.  Anxiously waiting. ?
So... on a 5.3 crew cab 4x4... what sort of top end numbers are you seeing / anticipating after the delete?
I know that the 4x4 police tahoes are limited to 121, and the 2WD versions with the lowered suspension profile are up to 139. The main difference is the tires are rated for the speeds.  I am guessing that there are some other upgrades that they do not put in the highlights section like a better balanced drive shaft.
I'm just happy that my truck will outrun something that is limited to 98, and even most Fords are limited around 100.  I use my truck as a Security Patrol vehicle, and as a body guard transport, so short bursts of 121 are certainly appealing.
