So I just got a new boat (only 17ft fiberglass) and was on the way to put it in the water for the first time and my 2018 GMC Z71 with 10k miles apparently can’t handle that, as within about 15 miles on the interstate I get a warning saying my transmission is overheating and I need to pull over and idle.
After a couple of minutes I was finally able to navigate through the control panel it said the trans temp was 258 degrees.
I was driving in tow mode.
After it cooled down to 210 degrees I tried again without tow mode and it was back to 241 degrees before I got to the next exit about 2 miles away.
Needless to say I’m pissed off.
How heavy is your boat? I can't imagine it overheating from that, especially if you're cruising interstate speeds with that air flow through the cooler.
I'd take to the dealership with the boat, drive it with a tech and show them.
Something that would be covered under warranty no doubt.
Yup took the words out of my mouth, take it to the dealer. the thermostat might not be working.
Did a quick Google search and found a thread on this site of another 2 people having the same issue with the thermostat not opening.
Could it still be the thermostat if it doesn’t do it when not pulling the boat?
We ended up unhooking the trailer (and swapping trucks) and my truck drove home without the boat in the 195 degree range.
I’m guessing like 1600 for the boat, 400 for the motor.
Just for reference, father-in-laws 2500 pulled the little boat with the transmission temperature at a cool 185 degrees...
And thus far today my truck has hit 210 driving around town... supposed to take it to the dealership tomorrow morning.
That is too high. I live in Central Florida and our ambient air temp is about 85-93F, and I am usually between 185-190F. Your transmission thermostat is probably stuck shut.
Sent from my SAMSUNG-SM-J727A using Tapatalk
What did the Dealer say?
Sorry, I jumped the gun.
Edited by BlancoSilverado
I am the first person I know of to have a stuck closed trans thermostat. You’re doesn’t sound like that.
I also towed and even raced once while towing 4klbs (before I knew my trans thermostat was stuck closed)
-My temperature never increased anywhere close to as fast as yours
-it never got above 230, that’s towing 3k lbs through the city of philadelphia for an hour
So here’s how to tell if your thermostat is stuck.
Thermostat opens at 190-200. when your trans temp is like 140-160 range, pop your hood, and feel the drivers side trans cooler line in the front of the truck. Then feel the passenger side.
If your thermostat is stuck closed, your driver side line will be about as hot as your trans temp says it is. Your passenger side line will be ambient temp until the trans reaches 190-200. Once it reaches target temp the flow gates should open and the passenger side should be nearly as hot as the driver side.
if you have trouble located the lines, you can follow them right out of the transmission. It’s just easier to check them at the trans cooler since you don’t need to get under the truck
the techs had never dealt with this and were stumped. I had to basically figure this out on my own and verify the thermostat wasn’t operating and then tell them to change it.
Oh and btw you need to change all your trans fluid out it’s burnt.
Edited by truckguy82
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 720 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
