What do y’all think bout the all light on mod
Has anybody done it, what do you think? Do you pass inspection or just disconnect it when going to get inspection? ? bout doing it don’t really use my highlight but if I ever do I’d like to have all lights on.
It's pretty awesome, I did it for a while in my 2014 with a diode.
But what I also found was that if I switched my headlights to manual "on" and then turned on high beams, I had low and high at the same time, which was awesome with highs and lows both having xenon bulbs.
Diodes came out, and if I needed the daylight effect, I switched to manual "on" and hit the highs.
Sent from my SAMSUNG-SM-J727A using Tapatalk
I think fog lights have a certain use that is spelled out in their name. I’ve compared the high beams to my normal headlights and it’s a minimal increase. I don’t use them.
No point in arguing about the usefulness (or legality) of this idea. But there is a pinned topic in the forum with more posts than you can ever read about it:
I just did this mod from Boost auto.
I haven't driven at night yet.
But I did this to my 93 Silvy with a relay for both high and low beams on at the same time but no fog lights and liked it.
Yeah I’ve never driven with my high lights as my regular lights seem to be bright enough but never know when I might have to drive down some dark unknown road, just seemed like a nice little mod
City driving I can understand that low beams are sufficient.
Driving Colorado mountain roads at night this helps to see better which is why I did this mod to both my trucks.
I was going to add an LED light bar mounted in the slot in the front bumper but decided this would work.
4 hours ago, Frankielozano214 said:
Ok dick, I think we all know that. Asking if anybody has done this mod and what do they think not for the your smart as remark
Hey buttercup I told you what I think about the mod. Don’t ask next time if you don’t want honest answers.
Lol that had me crying. Got to send that to my pops
Man, I just had to post that. I don't know you and mean no offense. It was just fitting.
I tried the manual light trick on my 2018 and it did not work.  Is it year specific or am I missing something?
i would definitely like the all lights on mod.  It may only be once in great while that I need it, but sometimes, it’s really dark, the dear are out and the more light the better.
14s, 15s, and most of the newer HDs have both/separate HI/low headlights.
Our 18s (16s+ in 1500) have single dual-element headlights.
large.AC48CE23-81EC-4832-B78C-18881A20FE2D.jpeg.3714e5004dfcf93782249136211d0d40.thumb.jpeg.3c3bf480a47db8db559b1a2f0c193d09.jpeg
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
