  • Replies 44
Top Posters In This Topic
Wow.  P20EE.... the same code that troubled many of us 2017-2018 model year owners with the duramax.  Took a year to get a fix.  In the meantime, my CEL came on probably 20 times.  Nice to see it comes back up in the new model.
I have a 2020 2500 Duramax a Silverado. Check engine light came on at 500 miles had Chevy reset and Regen comes on every 150 miles been in 9 times field engineer sent fix to government for approval
16 hours ago, Girthyhawg said:
2020 HD light just came in tonight 1900mi... will update after dealer visit.
Just left dealer...
p20EE bulletin #pip5664a
reset nox1 sensor and performed box deduct any test.
asked dealer if it happens again, I hear some ppl have issue every 150mi... he said it won’t, so I’m wondering if that bulletin was the software fix?
SES light on 4 times since order. 2500 DMax Denali. Going back in on 9/30. The light comes on after a prolonged highway ride then disappears. P20EE, emissions. Correct, no remote start when it’s on and it’s pissing me off. Picked up with the 35 mile run-in and now have 1600 miles.
Check engine light came on yesterday at 6091 miles.  Going to take it in tomorrow to see what the deal is.  Was towing 200 miles from home so that was fun driving home hoping nothing major was wrong.
Edit: OnStar was finally able to get the diagnostics to work and it's the P20ee code.
Edited by Irish80
Had the check engine light come on, on my 2020 z71 dmax and also remote start didn't work as well. I have 800 miles on it. I took it into the dealer and i will hear back and update as well. The remote start doesnt work anytime the check engine light comes on, that is a feature as another user said.
I was on a 1600 mile one way trip today and got the same check engine light...I was at 1650 on the odometer when it came on...OnStar ran diagnostics and told me to service at my convenience...it’s 20° where I’m at and would like to remote start...won’t be home until the 16th...I did get 20.5mpg over the 1630 miles...way better than my 19 power stroke
Picked mine up from the dealer last night P20EE emissions code 2nd visit.  The first time they just reset it, this time loaded new software for the NOx sensor so I will cross my fingers and wait.  BTW the code only comes in on long highway trips. It usually resets (SES light) on its own a few days after city driving.  Which is nice because you get your remote start back.
p20ee came on today on trip - stopped at dealer and they put new fix in - were also doing their trucks on lot
'Remote start disabled' if there is an active CEL was a 'feature' on earlier generations as well.
Dealer not filling the def tank at delivery has also been an ongoing problem, for as long as we've had def.
For many, this means and early and unexpected warning to add def -- and an assumption that it was because of high consumption rate.
Just like fuel tank level, the def tank is NOT filled at the factory.  For trucks purchased after sitting on a lot this is probably a good thing.
not checking DEF level is like not checking fuel gauge when picking up new at dealer. Its your fault. CEL has stayed off since fix at dealer last thursday. P20EE fix finally has worked.
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
