20 hours ago, BB&Chiveon said:
not checking DEF level is like not checking fuel gauge when picking up new at dealer. Its your fault. CEL has stayed off since fix at dealer last thursday. P20EE fix finally has worked.
Might be true on 2020's, if the 'gauge' is accurate -- I don't have a '20, but it sounds like there are issues with it.
2011 there was no def gauge at all -- just the miles remaining warnings.
2012 - 2019 have a def level indicator.  Won't tell you if it's full -- only gives a %  indication if it thinks their is less than 30%.  Above 30 it just says 'OK'.  Which of course is useless for 'checking to see if full'.
Ya, I know, it's a 2020 thread.
Edited by redwngr
  • Replies 44
Top Posters In This Topic
What was the fix for this problem. I’ve been to dealer 3 times and they said GM told them the fuel pump module is bad. I doubt this is the problem
On 1/20/2020 at 9:23 PM, Fl cowboy said:
I have a 2018 idling around today got a p026d code can anyone give me advice
Truck thinks it has a faulty DEF sensor.
I'd guess they will install a new one.
Let us know.
I'd still take it in and have the code scanned and documented.
I have a 2020 Sierra with 400 miles and the check engine light on.  I see others have had this issue.  Has it been resolved for most, or something I need to get used to.
Not something to get used to.
At 400 miles, get it to a dealer and make use of the warranty you paid for.
There are 100's (or 1000's) of things that could be the cause for the light.
Typically, much easier to find with some service training and with use of a diagnostic computer to help track it down.
You can hit the OnStar button, and they will give you the error codes / DTC's if you are curious...
Check engine came on my truck today at 15k. I went to auto-zone to get check and it wasn’t showing anything (maybe truck is too new for their device) and thn I called OnStar (P20EE) showed.
I’ll be going to dealer next week.
Edited by TrailDemon
I got the P20EE code at 800 miles after pulling a trailer for an extended period of time. I reset the light and it has not come back on in over 7000 miles.
Sent from my SM-G981U using Tapatalk
I hate to see that light so I reset as well. Already drove 100+ miles and still clear dash
  • 6 months later...
5,777 miles.
2020 Chevy Silverado 2500.
When put in drive, lags down, truck shuts down. Rear end locked up when trying to put on flatbed tow truck. Same email as others : engine and transmission issue detected.
being towed to the dealership as I type this.
12/28/20
17:00
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
