Kinda a simple question. Looking to change my Bow tie from the gold to black on my 2019 Silverado 1500 LT. Wanted to know if the option to pry the old bow tie off and pop the new one on, without having to take the entire front grill apart, was still possible, like it was for previous years.
I know now it might break the gold bow tie but I really don’t care seeing as I won’t be reusing it.
Thanks.
Edited by Pb14 42
Yup. If you have fingernails you can actually pull the old one off with your bare hands. I don’t have nails, so a plastic trim removal tool was needed. Just start at one corner, get a few of the clips popped off, and the thing just falls off.
You may break tabs and possibly dig impressions in the grille.  It's not hard removing the grille.
Edited by mafd2
Thanks!
1 minute ago, mafd2 said:
Not without breaking the tabs and possibly digging impressions in the grille.  It's not hard removing the grille.
I’ll keep this in mind, thank you
You’re better off just taking the grille off. Don’t be scared - remove the upper sight shield with the clips, the hood release lever, the 10mm bolts that hold the grille in then just pull the grille out toward you to release. It really is easy. Better than risking scratching or marring it.
Thanks.
Knife blade under the gold portion and pry off.....will expose the holes with the locking pins, screwdriver in hole to release (4) tabs...should know the locations from the replacemetn bowtie.....no damage to grille only gold and chrome backing plate, discard.....pop in new black bowtie.
Do you really want to remove the shroud and probably break a push pin or two then remove bolts.....and the pull real hard on the grille to release the clips.....forget a bolt or pull too hard and then you'll need a new grille?
It's all simple to do. Removed mine on my '19 and was a breeze. There's only 4 bolts on top so how do you forget a bolt? OMG really?  Even if someone was ignorant to not put any bolts back the grille still wouldn't fall off. I've Removed several grilles on '14-'18 Silverados and Sierras and never broke a push pin on the shroud. Never heard of such. They're practically unbreakable. Oh, and you won't break the grille.
Okay, you guys made me do it. ???
If you want to make a 30 second job take 30 minutes, and do it by the book, that’s fine. I do understand. But I just pulled mine off with my bare hands and put it back, completely unharmed in less than a minute just for the sake of this. The clips are not as tight (or fragile) as you think. It is exactly like the previous gen. The clips are the same. It’s really no biggie. I’ve never known anyone to pull the grill to do this unless they are fitting the lighted one.
  • Like 5
Great if it comes off that easy. I didn't take my grille off to change the bowtie I changed grilles. Just saying it's easy to remove and the post about breaking push pins, forgetting bolts and breaking the grille is a crock.
Does anyone know if the bowtie grill emblems from 2018 would fit the 2020s.
Thanks,
  • 2 years later...
Thanks,
Did you find out if they fit? Looking to do the same thing
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,891 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
