I bought a 2014 GMC Sierra 1500 that was in a flood I looked under the seat and all the seat motors are rusted the seats,radio,mirrors,pedal adjust doesnt work from the water damage just replaced the transmission from the water that was in it,wondering if theres a module that is stopping everything from working,the truck drives fine its just those parts thats not working that driving me crazy,any suggestion where the module is that controls the radio,elec seats,a/c, etc...
There are many modules that control those features, some of them are under the carpet.  Get yourself a subscription to AllDataDIY for access to the shop manual for diagrams and drawings and the trouble shooting guide.  You will save a fortune in time and money by getting yourself an MDI or MDI2 with GDS or GDS2 software so you can properly troubleshoot and not guess.
It’s been a while since I had my Sierra in deep water, but everything on these trucks seems sealed up well.  I’ve changed all my fluids since and have no evidence of water.  Many miles since and no issues.  Good to see others enjoying the outdoors and adventure!
This is the way in to the property I'm considering buying. What do you think?
Walk it and check the depth. No way to tell from a picture if it’s fordable.
Edited by Mawz
Autocorrect fail
One of my favorite phrases is: You will never know the answer unless you ask the question.
So, I would say go for it, just think how big the smile will be on your face when you get to the other side!!!
  • Haha 1
I've been able to determine through Google Earth that the current owner had constructed as least two bridges that were destroyed by winter storms, so access would be seasonal. I have considered using something along the lines of a monster truck, a heavy caterpillar or tracked bulldozer to get across, a heavy duty winch to pull a heavy duty trailer across, metal rope with pulleys sloping in each direction with a seat, constructing a rope bridge to cross during flood stage, making the creek wider and more shallow with heavy equipment (possibly illegal). It appears the creek could become 100 ft wide during flood stage. So I could possibly achieve seasonal access by driving thru after modifications. In the rainy season, a vehicle on each side and travel above it via rope, wire cable, the only way in. It would be like having a moat. I haven't been to see the property yet. A decent deal because of the lack of access currently.
So looks like it's affordable property that might not be fordable right now.... 🤣
    • In the 6.6 gas thread, I added information in my fluid change thread about these gauges and temperatures. With very limited data, it so far looks like ~30 degrees difference between front and rear.
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
