Transmission problems
Driving along and truck would not shift higher than 2nd gear. Really frustrating.  Seen a bunch of info regarding TCM causing limp mode. Were is the TCM and will it fix my problem.  2004 Chevy Silverado 1500 ext. Cab 5.3 L
04 does not have a separate TCM. It is all handled by the PCM. Take it to a trans shop for diagnosis. Strong possibility as noted above, it may be toast
11 minutes ago, Medic1 said:
TOAST!  Great. That just ruined my week.
Guess that means you completed diag and verified the ground cable was not an issue in relation to the TSB.
