19 hours ago, Kfroese said:
Cognito level kit with arms
1” bds block in back
amp steps
method grid 18x9 +18
ridge grappler 35/12.5
rides super smooth, haven’t rubbed yet
fantastic!
any trimming?
PISK?
Diff drop?
what did you do to the fender lights?
10 minutes ago, kylant said:
fantastic!
any trimming?
PISK?
Diff drop?
@kylant
No trimming
i didn’t do pisk. The shop said they really don’t think it’s needed for this adjustment
we didn’t discuss diff drop. Do you or anyone have opinion on if that’s needed for this?
smoked the fender the lights. They take them off and paint them translucent black from the inside. They still light up orange when on but black when off.
Edited by Kfroese
Spell error
7 hours ago, Kfroese said:
@kylant
No trimming
thanks.
don't know about PISK. I did it on my '15, didn't do anything on my '18 1500. don't remember if I did diff drops. I think I did on my '15
I have a superlift 3” on my new 2020 2500hd.  Kit includes new upper control arms, keys, front diff drop, rear 1.5” blocks and shock spacers for all four corners.  I switched out the factory Rancho shocks with bilstein 5100’s.  Running 37in ridge grapplers on factory 18” wheels.  It rides better than stock, tires rub only on frame (towards the cab) at absolute full lock.  I did cut the felt fender liner slightly on the front bumper side of the fender well.
this is my truck....love that look tho 35s would be sufficient for me?....but i like factory rims and have same ones.....so they just use torsion crank for lift it looks like......i wouldnt mind leaving block out and just getting another inch or so out of front.....it doesnt ride alot stiffer with keys cranked?
The front end height is achieved with new keys that are indexed differently than the factory keys, but doing that alone will give you a stiff ride.  That’s why the lift includes new upper control arms-to allow for appropriate travel between the bottom of the arm and the metal frame stop.  It also includes front differential drop spacers, which eliminates the bound up feel that these have when you just crank the keys up.  Those things, along with the shock spacers, will keep the ride nice.  I drove a truck for a day with this same setup on factory rancho shocks and I can say that my upgrading to bilstein 5100’s was well worth it.  There is a noticeable difference in ride quality.
The rear block, to me, was essential, because these new trucks have a lot less rake than in years prior, so you aren’t raising the front much before you are slightly higher than the rear.  I would not want more than the 1.5” block in the rear for me personally.  I’m not a tall guy and this truck sits up high by most anyone’s standards like this.
35’s with this setup on factory wheels will certainly work, and if 35’s is all you want, I’d leave the rear block out.  I have a close friend who has nothing in the rear with 35’s on factory 20’s.  It looks good, looks proportionate to the front just being slightly higher than stock.  But it does not have the stance that my truck has, not even close.  You could mistake his for being totally stock if you didn’t know better.
I'm thinking of getting the same kit. Was there a noticeable difference in the stance after installing it? I'd hate to install this kit and not get much of a difference in height.
Sent from my SM-A705U using Tapatalk
There is a huge difference in stance once the kit is installed.  You will not be disappointed in that regard.  My previous pic here doesn’t really do it justice.
I had a 6" on my 1500 but these new 2500s are already a little higher so i figured with the 3" kit it would look good. Really dont wanna get into cutting this one up although I like the look of a 5 or 6" kit. I'll mo as t likely gonwith this 3" kit. Also u upgraded to the bilstein shocks. Were they specific to the model truck or just general 5100 shocks
The shocks were ordered from summit racing, which was the fastest shipping of anyone I found.  They are specific to a GM 2500/3500 for 2020, although they may fit previous years, not sure on that.
front part number 24-253161
rear part number 24-196468
Just ordered the 3" superlift kit. Hope I like it!!!
So i got same kit as you. Did u have to do any trimming for 37s? I ordered 22x10 wheels -19 offset. Just not sure to go with 35x12.5×22 or 37x12.5x22 I dont wanna deal with major trimming issues
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
