Hello all, I was wondering if anyone knew or has tried to purchase the usb/sd card hub and see if navigation will work on the IOR radio. I know you have to purchase the navigation card then have it flashed at the dealer but I am curious.
I don't know if the IOR system can be upgraded with just an SD card.
Check out this thread...
This thread states that only IOS radios can be upgraded to NAV.  Don't know if that's true or not.
I suspect that the IOR will not support / recognize the NAV software.
These guys may know:
https://www.whiteautoandmedia.com/
I measured my screen and it is 8” not 7” like the IRO states in that thread. Maybe I do have a IOS radio but I do not have the SD slot. Really confused now lol.
Look inside your glovebox for your RPO codes and see what radio you have.
Post a pic of your RPO codes here if you want.  It's the "DNA" of how your truck was built.
The codes are on a decal in the glovebox, or at least should be.  I haven't checked with the 2019's yet.
2019s don't have RPO codes in the glovebox anymore.  It's on the door jamb and you need a QR reader.
Same RPO (IOR) is 7” or 8” depending on the trim level. On LT/RST the IOR is 8”. No card reader, no IOS.
I’ll bet the IOR is lacking some stuff behind the scenes, outside of the card reader, that would be needed to make it nav-capable.
  • Thanks 1
Thank you for your input!
  • 1 year later...
https://www.infotainment.com/collections/oem-chevy-silverado-navigation-radios/products/2019-2020-chevrolet-silverado-mylink-iou-gps-navigation-hd-radio-upgrade?variant=9365531820068
There is a nav only upgrade for the ior  radio.. i think you replace the whole radio  and it cost around 800.00 . I think your best using Android Auto or  car play. the Maps are constantly updated and no  map upgrade fees.  OHH And its Free.... To pay that much just to  add navigation is not worth it.. ohh it might had sat radio as well if you do not have that.
I looked into it when i get my truck so the info available may be some different now...
I have navigation in my 2016 and I hardly ever use it.  I don't have navigation in my 2019 and I don't miss it.  For those few times I do need nav I just use Apple CarPlay.  It's actually a much better way to navigate.
Do you have info for this? Last I checked, which was back in August, I was told GM abandoned the upgrade program.
not specific i just seen the  upgrade kit listed on a gm parts website. There was information about the  parts required and so on. and it was actually in August or early October  last year. We bought our truck early August . might be gmparts.com or something like that.
So your thinking  is Probably correct.
Yes GM does not sell the NAV upgrade kit any more. They did away with it sometime last year. You can't use a used SD card either as they are locked to the VIN of the original vehicle they were installed on.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
