Anyone have any issues with Steering Column noise- “Service Steering Column Lock”.
Traction Control seems to be acting up with left turns, could be related, not sure
I've had my service steering column lock come on twice but barely long enough to read the message.  I'm not sure what it means but I'm keeping an eye out for any issues with it.  Haven't noticed any of the other issues you mentioned.
Thanks, I’m taking it to the dealer this week to have them check out- definitely hearing some noises from the steering column, but no rhyme or reason. Will update after the dealer looks at.
Has the service department responded to the noise? Mine sounds power steering related. I took it to back to the dealer the second day I had it and the service department said it was ABS related and was normal but mentioned they would watch out for other similar complaints.  2020 Denali 2500 w/L8T.
Thanks for any input.
My silverado seems to have similar problem. Power steering makes all kinds of huffing and puffing noises and a little bit of grinding sensation when staring to drive. Dealer claims its normal. Im not so sure about it.
Hi Everyone, I was able to take it in to the dealer- they did the recall (Reprogram) for the engine light/nox sensor (emissions issue). They found three codes stored for the steering and chassis modules along with trailerbrake control module. They cleared them for the time being. I will update with the code numbers tomorrow.
Steering module lost connectivity was one of them- steering column still making noise. Advised to bring it.back when the service steering column lock message re appears.
I just got mine back this morning.  I had service steering lock message and side detection unavailable.  They say it’s a video module and it has to be ordered.  Don’t know why those 2 are connected but they say that’s it.  Will update after parts come in.  Also did the emissions update to get rid of cel periodically coming on.
Awesome, will look out for your update. As for the CEL, I’ve put minimal miles since the reprogram, but it definitely appears to be doing regens and acting normal now.
  • 5 months later...
2020 2500hd High Country...steering sounds like it is low on fluid. Dealership looked at it...still makes the ol fashioned low on fluid noise but steers fine. Sound familiar to anyone?
I have a 2020 GMC 2500HD AT4, and am having all kinds of the same issues my steering is really noisy and lots if rattles and vibrations dealership says its normal, but I disagree. Steering column pop up is also coming on, anyone have any new news on this or fixes? the put a new power steering pump on but still didn't help and a new steering shaft below the steering wheel which was already worn out after 10k they said.
Sounds like bad news for these new trucks.
Second post...been to the dealer twice now
Chevrolet says that the DIGITAL VARIABLE ASSIST steering system may have noise associated with it. Sounds like old fashioned flow restriction or low on fluid to me. And it’s louder than the exhaust. My buds Ram 3500 Laramie Longhorn makes no noises and he has much nicer interior. I’m a GM guy but....why Chevy, why?
Mine makes like a rushing water sound or hissing noise when stopped and as soon as i drive it goes away.  Doesnt affect the steering and haven't gotten and codes or anything like that.  Will have to have the dealership look at it when I get a chance
That is a good description of the noise and issue. My 2020 Denali 2500 6.6L makes the same noise. I assume other posts have a Duramax , so it’s not an engine issue. I found a technical bulletin regarding power steering noise on earlier models but it is related to extreme cold weather (-31 deg F), so maybe it is fluid related. I wish the dealer would just try the fix to see if it works in warmer conditions. The noise is very annoying.
I will attach the tech bulletin. Please update what your dealer says.
mc-10163270-9999.pdf
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
