Just got back from first long Freeway trip and while washing Trail Boss found first rock chip in hood. Has anybody put on a Bug shield / Hood deflector if so what kind and photos please
3m clear Film - Whole front end ( grill/bumpers ) , 8" on hood , mirror caps , door still . NO problem with chips .
Put it on after first paint chip a week after I got it. Its AVS brand. I like it. Easy 3M install
I got mine from the Chevy Accessories website. Took this picture when I swapped out my bow tie emblem to the black one. You can see the old one by the hood deflector so don’t think those little spikes are part of the molding. But I love mine! Looks awesome. ?
Aeroskin II® Hood Protector in Textured Black by LUND® - Associated Accessories
Part No.: 19417399
MSRP: $109.00 | Quantity: 1 | Delivery Method: Pickup at Dealer - No Additional cost
https://accessories.chevrolet.com/product/aeroskin-ii-hood-protector-in-textured-black-by-lund-associated-accessories-19417399?year=2019&make=Chevrolet&model=Silverado 1500
Part No.: 19417399
Does it use the 3m tape or Clips?
IMG_20191010_175024736.thumb.jpg.3e10d579e83d32ea4d8ba3f9ef1993db.jpgi have an AVS bugflectorII. it was ok install once i got some plastic push clips that were
actually big enough to hold it in place the provided plastic rivets are useless..
i will try to get pics up later it actually looks ok on it and the smoke color blends pretty well with the satin steel paint scheme
Edited by newLT290
What size / type / brand push pins you use?
I have an AVS bugflector coming this week.   Might as well be ready for it.
3M Tape it’s very secure and doesn’t give at all.
Part No.: 19417399
Looks great!  How's the wind noise at 60+ mph?
I just had my truck ceramic coated and not sure if the 3M tape will hold or not. Plus I'm not crazy about putting something on the truck with sticky tape. Can yours be taken completely off without opening the hood or is it pretty secured? Yours looks great!
Edited by DanTN
You can definitely tell the difference in added wind noise.
It can be taken off completely without opening the hood - tt's attached with the same material that the truck badges/decals are affixed with so there's no quick removing it. They provide you with alcohol wipes -- maybe it'll help with the ceramic coating? And thanks!
Thanks - looks great.
i used like a 1\2 to 3\4 long by 1\8-3\16  Christmas tree push pins i had laying around the house ... sorry haven't gotten pics up  truck is the wife's DD and she gets home after dark daily
also when i used these push pins they were a bit bigger then the sent plastic rivets so i had to gentle tap them into the holes in the hood with a rubber mallet just until they would hold the shield
Edited by newLT290
more info
    DM22
    DM22
  • Who's Online   6 Members, 0 Anonymous, 1,706 Guests (See full list)
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
