Looking to put a Cold Air Intake on new 6.6L Gas. Never put one of these on anything I have owned so don't know if they make a real difference.
Any feedback, opinions, suggestions, etc.?
Brand?
Who to buy from?
Basically, they make your engine a bit louder.  It's been decades since manufacturers put a intake tube on that was too restrictive for the engine.
It is functional on the duramax only.
I haven't seen any companies making 6.6 intakes yet, the trucks have only been on the market for like 2 full months now.
Well durka durka!
We are developing a very high quality CAI system for the 6.6L gas truck. It will be similar in appearance to our GM 1500 CAI pictured below!
We are receiving awesome feedback and reviews on the 1500 CAI when it comes to quality, performance, and fuel economy! More info coming soon on the CAI for the 6.6L gas trucks.
I love powercore filters... never have to clean them and I install the prewrap mesh....
Just got the Cold Air Inductions CAI cold air intake for my 2019 6.2 Sierra Denali and it sounds NOTHING like the same one they sold for my 2017 6.2 Sierra Denali. So bummed. Any body have any thoughts?
  • 11 months later...
Where is roto-fab on production of this? I had a roto fab set up in my 2010 camaro ss and I loved it.
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 457 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
