oem fog light upgrade? 2018
I am asking if anyone has upgraded these dismal oem factory led fog lights?, I tried searching the forum but didn't find anything specific, also tried looking for better fog lights on the web and also didn't find anything worthwhile
i am talking about these (3 tiny led oem fog lights)
Baja designs has a replacement kit now that I've looked at but havent purchased yet.
https://www.bajadesigns.com/products/Chevy-Silverado-16-18-Fog-Pocket-Kits.asp
Sent from my SM-G975U using Tapatalk
These LED ones are far better than the normal fog lights on my previous 2012 truck. I think these ones work great lol.
Anything brighter and people would start flashing me going by because I'd just be blinding them.
thanks $564 and back ordered, lol ouch
Yea that's why I havent got them yet is because of price. The sport lights are $500 and brighter than the SAE.
They are proud of those, if I could come up with a bracket like that then it would be easy to throw in some off the shelf lights, I have a set of round pod shaped led's that would fit just right with a bracket, I might have to take one of these out and have the local machine shop fabricate some brackets
I think the fogs do a great job (stock LEDs on a 2018 Z71) as FOG lights.. they're not off road lights though..
8 hours ago, L86 All Terrain said:
Us 2014-2015 guys lucked out. Morimoto made a set for both Silverado/Sierra but didn't make a new set after the 2015 face lift. Spyder makes a set, but they aren't any more visually appealing than the OEM ones. http://spyderauto.com/categorylist.php?id=fog light&make=Chevrolet&model=Silverado
ya I was looking at the spyder ones but they don't look like anything special, I may have to pick up some cheapy aftermarket ones and see if I can mod something up if I cant at least come up with a bracket, or just completely gut out a aftermarket set and use it as a bracket
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
