Oil plug Dorman vs Gold Plug
Factory oil plug has been leaving a drip every once in a while since I did my last oil change. Monitored it but never more than a drip every few days. Time for a new oil change so looking into replacing the plug Finding lots of replacements from the Dorman 090-091 to Gold Plug AP-04.  One uses the factory o-ring type seal while the other uses an aluminum crush washer. Any recommendations or pros/cons on one vs the other? Not really interested in the Fumoto type plugs
edit:
missed the part about no fumoto.   i think either one you are looking at will be fine.
Factory plugs are not magnetic like they used to be either.  First thing I did was pick up a new magnetic drain plug from Napa, looks and performs just like OEM except it has the magnetic tip.  Not sure why or when GM stopped using magnetic plugs but it's well worth the few bucks for a replacement in my mind.
Fumoto. Whether you’re interested or not it’s simply better than the 2 you’re looking at
Don’t go with the gold plug ap-04 mine leaked with the new washer went back to stock plug ?
Good to know. I was leaning toward the Dorman plug
Thanks everyone
