Do you already have the Tow package?  If not, could be the wiring for the trailer...
If you do, could possibly be the trailering camera??
you got any pictures?
Are you looking at the hole to stick the crank in, to lower the spare tire?
1 hour ago, imadebogey said:
Anybody know what the plug behind the license plate is for?  I've searched but come up with nothing.
Could you provide a picture of the hole?
Makes guessing a lot easier.
I already put the license plate on.  I'll snap a picture tonight.  When I took the dealer tag off to put the license plate on, there is a plug just sitting there behind the plate with nothing plugged in to it.
Tow package, rear (back up) camera, and the LED lights mounted under the bed rails from the factory come to mind.
But take the picture, that way more might be able to help.
Already have the tow package.  I guess the trailering camera would make the most sense.
No.  It's not a hole.  There is just a plug hanging loose there.  I'll try to get a picture tonight.
I put my plates on over the weekend and didn’t pay much attention as my kids were running around in the street. Pretty sure I saw wires and a plug too. Was too busy yelling at my kids to get out of the street to take a good look. Now I’m curious. Will have to investigate.
Pretty sure it’s the plug for the wireless trailer tire pressure sensors. Had a look behind my license plate and there’s a black box there connected to that plug. Does your truck have the trailer tire pressure monitoring?
No it doesnt. That is probably what it is.
Sent from my SM-G975U1 using Tapatalk
Does it have a green plug? When I wired my Putco Blade tailgate lightbar using the Putco Blade quick connect harness I plugged into a previously unused connector.
https://www.putco.com/529005
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
