I have a Roll N Lock Cargo Manager, it was included free as a promotional with my Roll N Lock Tonneau cover. It is a movable bed divider that can be positioned every 3 inch along the length of the truck bed. Works great!
On 12/4/2019 at 3:28 PM, Ryno12 said:
Yep, I use a 2x6 also. I sprayed mine with bed liner coating and also made moveable pieces that prevent items from sliding side by side.
Just curious which spray you used. That looks relatively smooth which I'm looking for. I'm assuming most of that cans spray that smooth vs rough roll-on?
I used Herculiner in a spray can. It’s a tad more expensive but it goes on thicker & doesn’t run as easy as the Rustoleum I’ve used before.
On 12/4/2019 at 5:39 PM, 2k19Sierra said:
Couple 2 x 6’s have always worked for me! The grooves in the bed and tailgate hold things nicely in place when driving. That and some good toolboxes that lock together works perfectly. Oh and the multi pro tailgate is absolutely amazing. Makes the whole bed so much more accessible! 34935C97-9336-4BD4-8FD6-DACFA197420A.jpeg.85520b958f6f9ca7f54222769fdffc3d.jpeg
OMG, I didn't know we were allowed to put tools in a truck any more??
Been in construction over 40 years here. ?
Which tonneau do you have/do you like it?
Haha that’s what trucks are for isn’t it?!   nicest work truck I’ve ever had that’s for sure!
the tonneau cover is the gm branded one by REV. It’s very nice! Lots of different configurations that it folds into including right up and out of the way for bigger items in the bed. It’s not totally waterproof but good enough for me. And very secure to keep tools secure.
  • 1 month later...
Thanks for the idea!!... finally got around to making mine... here’s a pic of it installed. I have the little divider piece but didn’t take a pic of that.
  • Like 3
Logo is a nice touch.  How did you manage to do that?  Very cool!
Thanks! I work for a large format printing company and I snuck it on with a job and had it CNC’d and then pinned it to the 2 x 6 before coating... shhhhhh ?
Looks great! I like the added detail.
  • Thanks 1
How much was that cover and from where
I purchased the GM net for the front area of my box. What I like about that is when I’m placing longer items in the box, like lumber or ladders and such, the net is flexible enough to just stretch forward against the box. It also contains a pocket that I store my tie down straps & jumper cables in. With the 2x6 up front, I was always having to crawl up in the box to remove it for longer items, so I leave it in the rear slots where it’s easily removed if the need arises.
The net up front makes good use of the 2500 side steps & my Extang Encore tonneau cover. I can flip the cover back and pack items up front if need be.
I know it’s not bed management, but since we’re on the subject of storage, I placed an extra battery box I had laying around in the spare battery location under the hood. Now I can place small tools or any items that can take the heat, up under the hood.
Edited by Ryno12
It was $1,209.99  @ tonneaucovered.com
At the the time of purchase, roll-n-lock had a promotional going on and I got the Cargo Manager for free.
Just noticed you name on here the B4U, is that a 94-96 Grand Prix reference?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,249 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
