Cooper discover AT3 XLT?
  • Replies 40
Merry Christmas! Has anyone ran this tire?
Sent from my LG-G710 using Tapatalk
I have a set of AT3's on my old f150. They are good tires. Good rain and snow traction, did well on the sand at the outer Banks. Long lasting. Only complaint is they started roaring after a few thousand miles.
Sent from my Moto G (4) using Tapatalk
Nice I can live with the noise. The stereo will be on most times.
Good tire for sure.  Falken Wildpeak AT3W are better in my opinion.  My set are now past 60k and probably good for another 10k.  Excellent wet traction throughout the life of the tire.
Though that’s great to hear, I’ve heard mixed reviews on them, starting out great then weaning off as they get miles on them. My Nitto Ridge Grapplers lost their siping abilities at approx 16K miles, tossed them. I’m running new KO2’s now, always had BFG AT’s and zero issues.
Sent from Above
Merry Christmas [emoji319][emoji320]
Sent from Above
 I got them last month on my 2008 and so far I really like them.
Hows the grip in the wet weather?
I’d be looking at its performance at mid-life of the tire cause just about everything out today does well when new.
Sent from Above
Sent from Above
Agreed.
I'll look into those as well. Im sorta partial to the coopers due to the white letters. I've been an 70s-80s fan of the white lettering on tires.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
