On 2/20/2020 at 6:29 PM, Flatblack83 said:
The led fancier truck style headlights with the drl have grown on me. So I'm going to do a change to the front end, I bought a set of led headlights, black grill and a wiring harness. Hopefully I can do this in about a week or so.
Mind sharing more info on the harness? Where did you source the lights?
Thanks!
Thanks!
Gen5diy.com for the harness. For the headlights and grill I used Ebay..made offers on em, if they didnt take my offer I moved on.
Nice truck. I like those headlights more then the custom ones but I prefer the custom grill without the bow tie. I wish we had some aftermarket options for headlights.
Agreed.  I have a Custom Trail Boss and I like the big CHEVROLET grill, but I like the look (and performance) of the LED headlights that I don't have.
It doesn't look like we could just use the LED headlights with the Custom grill though.
I need to get off of my butt and order the fog light retrofit from GM too, as I really feel that I need some extra lighting.
How difficult was the front end swap? Was everything pretty much plug and play?
Looks like a great mod that I'd be interested in.
Sorry I missed this.  It's all plug n play with the harness I posted above.
A few months ago I installed a gibson catback, it's already rusty brown and looks awful. Sounds fine just looks bad. So I put the stock exhaust back on with the muffler delete . Well that turned out bad too, honestly it sounded ok but start up and low speeds its sounds awful. Today I installed a borla s-type, fit and finish is perfect. Start up is loud but not as bad as the delete. The tone is really impressive and no drone whatsoever.  That's what I get I guess for not just doing it the 1st time.
So it was time for a few more small Mods, I did an airaid cold air tube with a green filter in the stock airbox. Jlt performance catch can, fit real nice. I chose the black version to fit in a little better. Lastly I did diode dynamics license plate and reverse led cool white bulbs. The trucks now all led and the lights are all nice and crisp. Yes under the hood is dirty, it's due forva good cleaning.
Edited by Flatblack83
Hey what is the part number for the airaid tube if you don't mind me asking?
On 12/27/2019 at 5:29 PM, Flatblack83 said:
Readylift 2 inch level, 295 60 20 wildpeaks, painted mirror caps, stock led for lights, morimoto low beams and a tri fold toneau.20191226_192352.thumb.jpg.e7351502aef39606a6be3df353d7e01f.jpg
So did you replace the factory headlights with factory LED headlights and bulbs?
Edit, I see you did. Congrats on doing it right, though they look a little high as they are in the mirror of that taller jeep. So many people just throw in LED's in a reflector housing and blind everyone on the road it is annoying at best and just dangerous for certain people. One company I saw came out with a bulb that is close to acting like a factory halogen bulb and mostly gets rid of the blinding scatter, hopefully more follow suit but I don't have high hopes many will.
Nice job!
Tyler
Edited by amxguy1970
Nice job!
Tyler
Since my trucks a custom it came with the halogen housings. That pic I did just the bulbs in the stock halogen housings. I used morimoto 2 stroke bulbs. They were really bright and as nice as stock led.
I did the light swap after that to what I have now only because I got a good geal on stock full led housings.  The led bulbs are actually for sale in the classifieds.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
