My truck was leveled out at about 1.5”. It actually sits 1/4” higher in the front right now, so I’m due back at the shop on Monday for a re-torque, final measurements, and any other needed adjustments. I actually stopped by the dealership yesterday & got a copy of the recommended alignment specs for my specific vehicle. I was curious to see how it differed from alignment after the kit was installed. So there are some slight discrepancies in caster and toe. The steering kind of settled in over the last day, but I feel like the steering is stiffer than what it used to be, prior to the install.
Anyway here are some pics of how it came out. It’s sitting on a decline and looks good. It’s only when I park it on a bit of an incline Does it begin to look nose high & so I begin to wonder if I should have them bring it down to 1” of lift in the front. It’s weird with the GMCs because of the way the wheel well is designed and the aggressive grill, with the slightest lift It looks nose high.
After about 1k miles and hearing other people's reviews on these icons I figured I'd call them. My truck rides too firm for my liking but drives really well. I was told the non reservoir have spacers inside to limit travel. It would need to be removed. So instead I turned all the preload off the coilover and put a moto fab 1/2 inch spacer under it. That pushes the shaft up off of the internal spacer giving more room. So far so good, still at 3 inch lift and rides smoother.
6 hours ago, Kableguy said:
Jtlans- what tint did you go with on your windows? Getting mine done soon, yours looks good.
I am uncertain. I just took it to a local tint shop and just told them to match it to the rear. I would guess that it's 15 or 18%.
I have a 2020 Custom that I have done a few things to. A before and after comparison is attached.
Wow! Very classy!
On 1/15/2020 at 5:26 PM, Flatblack83 said:
All cleaned up, ready 4 Saturdays snow fall. Heres the newest if the stance with the side steps.
This is a really really good looking truck. Love the colors, wheels, lift steps, all of it. Well done sir
  • Thanks 1
The led fancier truck style headlights with the drl have grown on me. So I'm going to do a change to the front end, I bought a set of led headlights, black grill and a wiring harness. Hopefully I can do this in about a week or so.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
