2 hours ago, Libertas said:
84644535
84644536
They are separate part #'s for the Left and the Right.  In the parts catalog, they are listed as F Sleeve
Thank you.
On 2/29/2020 at 6:14 AM, 2000 said:
Thank you.
You're welcome.  I just had an exhaust shop put on my Borla exhaust today, and requested they change out my exhaust tips.  Unfortunately, they said they couldn't get to the bolts to do it.  I am faaaaar from mechanically inclined, so now I'm not sure what I'm gonna do.  Might have to check with the dealer to see how much they would soak me to install them. ?
Installed my black tips tonight.  It was definitely a struggle getting the first one done, it’s really tight under there.
For me a 10mm ratcheting wrench was key to the removal and reinstall. First remove the top bolt with a 10mm ratchet & extension. Once the top bolt is out, you can pull down on the tip and this will allow more access to the left & right bolts. Remove the inside bolt first and outside bolt second with a 10mm ratcheting wrench. Repeat in reverse order when installing new tips. Don’t fully tighten the left or right bolt until you’ve got both bolts started.
Ordered mine today.  Thanks for the part numbers guys!
 Still want to do something with the GMC logos as well.  Going to go with Bronze Fuel wheels so think I am just going to get rid of as much of the chrome as possible.
  • 4 months later...
On 2/3/2020 at 12:43 AM, Dick Messerly said:
84690478 is the bigger door one 84690479 is the smaller tailgate one.
Anyone else getting the description as "F Plate" for the door badge? Tailgate one is full description, but door one basically says nothing.
Looks sweet on the gray color truck. I went with black for body color, probably wouldn't look at good on mine; wouldn't even be able to see them.
On 1/29/2020 at 9:56 PM, Dick Messerly said:
Also decided to plastidip the gmc emblem I don't get why they don't just make them like this it looks so much better!
did you take it off to do it
  • 3 months later...
On 1/30/2020 at 12:49 AM, Dick Messerly said:
Got the new carbon flash black AT4 emblems! They are looking great!!!
Any “how to’s” to line up the replacement emblem?
Small air ratchet.... it'll slide right in there.
Those badges look awesome!!!!!   I plasti dipped my 2014 Denali badges black.   The only issue I had was the front would chip and flake from rock strikes.  So I would touch it up every couple months.  Anyone have suggestions on making the front panted emblems more durable?
I ordered some decal overlays and did mine.
How hard were these to line up when installing? Not a bad option for $20 or so.
I am no expert and found them to be not too bad to apply. They fit just inside the chrome layer and I used a blow dryer to heat up and a credit card to tuck the edges
    1GIO44
    1GIO44
  • Who's Online   2 Members, 0 Anonymous, 715 Guests (See full list)
