On 6/25/2020 at 10:13 PM, Stand By said:
Have you contacted White's or anybody to see if it could be programmed?
On 6/25/2020 at 8:51 AM, Zelas said:
I Have swapped out my Steering wheel with a Leather wheel which has the Buttons on the right. I also have swapped the Speedometer with a High Country one. It does not work . The Cruse control buttons work however, I have to reinstall my old speedometer because I am not able to toggle thru the menus. Its a bummer because it makes a huge difference in the interior.
I think you also have to swap the 7” monitor functions out for the 8” display model. That also carries all the information for this switch to happen. I have tried this but I’ve wanted too so bad.
  • 3 months later...
Did anyone find a way to add the buttons on the right?  Just got my 2021 2500HD Base and it doesnt have the volume on the right either.  The blank is there.  Can it be added?
After researching the addition of radio controls on the steering wheel, I've concluded it can't be done without a huge hassle and expense.  As an alternative, I swapped in the leather steering wheel and used the blank on the right side of the stock wheel that came on my 2020 Silverado Custom.  I have Katzkin leather seats so I wanted a leather wheel to match so at least I have a nice steering wheel instead of the cheezy plastic stock version that came on on the Custom trucks.  The cruise control buttons on the new wheel work fine.
Edited by Mac-427
  • 4 months later...
Someone on YouTube added the steering wheel controls on a 2021 Silverado custom.  And harness dr has the line bus harness to add steering wheel controls. But I believe you have to upgrade the cluster as well and swap steering wheel.
I was able to work with the Harness Dr on my 2021 Sierra 3500 base, to get this working. I added the programmed cluster from WAMS, a steering wheel with the menu controls on the right and audio controls on the back. We added 1 wire (now available on Harness Dr website), which required no splicing, pinned at the cluster and pinned at the clock spring harness and this gave my wheel full control. Well worth while upgrade.
Hey Vradcliffe, this is a  pretty big deal for lots of us on the Forum.  Any additional detail would be sincerely appreciated.
Hey Mac-427, I’ll try to add some detail so forgive the long post....
the first thing I would do is remover the upper steering column cover, to expose the clockspring harness (yellow connector). If you remove the harness, you can verify if there is any existing LIN bus connection (slot 9). If there is no connection, you should be able to run a wire directly from slot 9 at the clock spring along the existing harness to slot 20 at the cluster connector. I would really recommend going to the Harness Dr. website and purchasing the wire for $26. It will come with full instructions (many of the pics are from my upgrade, just saying that as verification it worked) and it is pinned perfectly to fit in the slots.
Just as an FYI, I DID NOT replace the clock spring, as I’ve seen many people believe that may be necessary for this upgrade.
This upgrade has had at least 2 additional successful attempts that I’m aware of, to this point.
Thanks Vradcliffe.  I'm following this issue closely because I have the steering wheel controls that came with my replacement leather wheel so I'm at least part of the way there.
@Vradcliffe,
Thanks again for your involvement in this.  Your patience and dedication to see this to fruition is greatly appreciated.
Foe those looking into this, the harness can be purchased here.
https://harnessdr.com/product/2019-2021-silverado-sierra-steering-wheel-lin-bus-harness/
A few things to note:
A new compatible cluster swap is needed.  The new cluster needs to be custom programmed by WAMS - 2019+ (T1) Denali / High Country Cluster Upgrade Kit - White Automotive & Media Services - @GTPprix is the only company I use for this type of work.
Since a new cluster is needed, might as well upgrade to the nicer Denali or High Country Cluster.
A few customers have also reported that they gained radio controls (IOR) radios and have restored backlight illumination on the left side.
Keep in mind, that this is still a fairly new retrofit and release - so individual results may vary.
Thanks!
On 6/9/2021 at 12:43 PM, Vradcliffe said:
Here are the before and after photos....
I apologize, the before photo is the dealer stock photo, I didn’t take one prior to the install...
That does make for a great look. Would happen to have the website where you ordered the parts?
Thanks!
I completed this and everything works except the heated wheel. Ordered a high country cluster from whites, wire from harness dr and a wheel from the dealer. Cost me about 1k to complete. Yes that's alot but its really nice..!! Since it's a custom the stereo bezel didn't match, I ordered the silver one to match.
Edited by Flatblack83
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
