Hello,
I just got the GMC Sierra AT4 2500HD online it says 36 gallon gas tank, I went to fill up today for the first time because I was getting close to empty and it took 25 gallons. Does anyone know if the 2500s actually have the standard 28 gallon tanks and not 36 like advertised?
My CCSB 2500 gas also has a 36 gal tank.
How close to empty were you? Was the gas light on?
I have a previous gen but it’s still 36 gallons and if I’m bone dry (driving with the light on for 15-20 miles) it’ll still only take 31 gallons. So could be that you just filled up before it was empty. Just a thought.
All HD AT4's (and denali's) are crew cabs.
All HD crews have 36 gallon tank (cab and chassis trucks excepted)
HD Double cab std box diesels are 29, gassers 36. DC long box are 36.
HD Reg cab gasser = 36, diesel = 28
I'm surprised they have both a 28 and a 29 in the system.
I've put 132 litres in my 2018, (which is also supposed to be a 36 gallon tank).
That's 34.8 usgal.
I don't make a habit of that, but am often at 128 to 130 litres (about 34 usgal)
Estimated range screen changes from a number to a 'range low' message somewhere in the 50 miles remaining range. :driving:
Edited by redwngr
Well to be fair it said I had 109 miles left so I guess not to empty...I’ll wait longer next time
That's 34.8 usgal.
Thank you for this
I've put 32.93 gallons of gas in my 2020 and low fuel light on and I think it said Range Low. Pretty nice to be able to run that long on a tank compared to my old 1500.
That’s about right then for a 36 gal tank. I’m currently showing 117 miles left with just under a quarter tank on the gauge.
Quarter tank=9 gallons
  • 6.6 Gas L8T, All Box/Cab Configurations: 36 Gallons
  • 6.6 Diesel L5P Double Cab Long Box/Crew Cab Standard and Long Box Configurations: 36 Gallons.
  • 6.6 Diesel L5P Double Cab Standard Box Configuration: 29 Gallons.
  • 6.6 Diesel L5P Regular Cab Long Box Configuration: 28 Gallons.
I have a 6.6 Diesel standard box At4 2500HD
what are the differences here;
crew cab?
double cab?
regular cab?
crew cab?
double cab?
regular cab?
Are you asking what the differences are between the CC, DC, & RC?
I think he's asking how the gas tanks are designed to fit the different cab/box configurations? I'm assuming the gas tanks are just molded to fit in the most available spaces on those trucks, and still be able to be removable for service.
    • A little girl said her prayers every night before bed and she asked G d to watch after each person she loved. One night she forgot to pray for her babysitter and her babysitter died. A few days later she forgot to pray for someone else and they died. The next night she forgot to pray for her dad. The next morning her dad was terrified. A bus almost crashed into him. He almost fell off a fifty foot ladder and almost wrecked on the way home. When he arrived home, he said I had a terrible day. His wife replied, “You think you had a bad day? My aerobics teacher died during class.
    • Nice! I had one here, once. The car dealer I used to haul for stopped by with it. That was over 10 years ago now. Those are SUPER rare these days, especially up here! Never even see them at car shows anymore.   https://postimg.cc/0rvcNZ1W
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
